NetApp Console setup and administration
Manage partnerships in NetApp Console
Contributors netapp-tonias
Create partnerships to establish secure, managed connections between your organization and trusted partners for collaborative NetApp resource management.
Partnerships let you securely manage NetApp resources across boundaries with role-driven relationships in the Console. The initiating organization grants access to its resources, while the accepting organization provides the users or service accounts to be granted access. Partnerships are established through a self-service workflow, giving the initiating organization full control over which resources are shared, what roles are assigned, and the ability to onboard, manage, or revoke partner access as needed.
Required roles
The Partnership admin role is required to create and manage partnerships. The Partnership viewer can view the Partnerships page. Learn more about access roles.
Initiate an organization partnership
You can request a partnership with another organization if you know their organization ID. The receiving organization approves the request before the partnership can proceed.
Before you begin, ensure you have the organization ID of the partner organization and that you have been assigned the Partnership admin role.
Steps
  1. Select Administration > Identity and access.
  2. Select the Partnerships tab.
  3. Select Add partnership.
  4. In the Create partnership dialog box, enter the partner organization ID of the requested partner and select Add.
    The partnership request is sent to the partner organization for approval. You can view the status of the partnership request on the Partnerships page.
Approve an organization partnership
An organization partnership request must be accepted by the receiving organization before the partnership can proceed. You must have the Partnership admin role to approve and manage partnerships.
Steps
  2. Select Partnerships.
  3. Select the Partnership received tab.
  4. Navigate to the received partnership you want to approve and select An icon that is three side-by-side dots and then select Approve.
  5. Review the details of the partnership, including the name and organization ID of the organization that requested the partnership and select Next.
  6. Optionally, add organization members to the partnership and select Apply.
    You can add additional members through the Partnership page at any time.
    Note Any members you add become visible in the partner's organization where the partner can assign them to resources.
Result
The partnership you approved now shows a status of Established. Users with the Partnership admin or Partnership viewer roles in either organization can view the partnership.
View partnership status
View the status of your partnerships.
Required role
Partnership admin, Partnership viewer. Learn more about access roles.
Steps
  3. Select either the Initiated partnerships or the Received partnerships tab.
  4. Review the respective table that displays partnerships and their statuses.
Disable an organization partnership
You must be a member of the initiating organization to disable a partnership. Disabling a partnership immediately revokes access to any resources in your organization that were shared with the partner organization.
Required role
Partnership admin. Learn more about access roles.
Steps
  3. Select the Initiated partnerships tab.
  5. Navigate to the initiated partnership you want to disable and select An icon that is three side-by-side dots and then select Disable.
