Manage your NetApp Console user settings
You can modify your Console profile including change your password, enable multi-factor authentication (MFA), and see who your Console administrator is.
Within the Console, each user has a profile that contains information about the user and their settings. You can view and edit your profile settings.
Change your display name
You can change your Console display name, which identifies you to other users. You cannot change your username or email address.
Select the profile icon in the upper right corner of the Console to view the User settings panel.
Select the Edit icon next to your name.
Enter your new display name in the Name field.
Elevate your role in read-only mode
In some cases, your Organization admin may put your organization into read-only mode. If you have an admin role, you must elevate permissions to make changes. This ensures changes are intentional and authorized.
After elevating your role, you can make changes in the Console until your current session expires.
When you're finished, either log out of the Console or move the slider back to return to read-only mode. The system removes your elevated permissions when your session expires.
For Read-only mode status, move the slider to the Elevated position and confirm the changes.
Configure multi-factor authentication
Configure multi-factor authentication (MFA) to improve security by requiring a second verification method.
Users who use single sign-on with an external identity provider or the NetApp Support Site cannot enable MFA. If either of these are true for you, you don't see the option to enable MFA in your profile settings.
Do not enable MFA if your user account is used for API access. Multi-factor authentication stops API access when enabled for a user account. Use service accounts for all API access.
You must have already downloaded an authentication app, such as Google Authenticator or Microsoft Authenticator, to your device.
You'll need your password to set up MFA.
If you do not have access to your authentication app or lose your recovery code, contact your Console administrator for help. |
Select Configure next to the Multi-Factor Authentication header.
Follow the prompts to set up MFA for your account.
When you finish, you'll be prompted to save your recovery code. Choose to either copy the code or download a text file containing the code. Keep this code somewhere safe. You need the recovery code if you lose access to your authentication app.
After you set up MFA, the Console prompts you to enter a one-time code from your authentication app each time you log in.
Regenerate your MFA recovery code
You can only use recovery codes once. If you use or lose yours, create a new one.
Select
next to the Multi-Factor Authentication header. -
Select Regenerate recovery code.
Copy the generated recovery code and save it in a secure location.
Delete your MFA configuration
If you are unable to access your authentication app or recovery code, you will need to contact your Organization administrator to reset your MFA configuration. |
Select
Select Delete.
Contact your Organization administrator
If you need to contact your organization administrator, you can send an email to them directly from the Console. The administrator manages user accounts and permissions within your organization.
You must have a default email application configured for your browser to use the Contact admins feature. |
Select Contact admins to send an email to your organization administrator.
Select the email application to use.
Finish the email and select Send.
Configure dark mode (dark theme)
You can set the Console to display in dark mode.
Move the Dark theme slider to enable it.
