NKMO Clusterrole YAML Example
The kubectl component of the NetApp Kubernetes Monitoring Operator (NKMO) needs to be configured with access to the following kubernetes objects, at a minimum: agents, clusterroles, clusterrolebindings, customresourcedefinitions, deployments, namespaces, roles, rolebindings, secrets, serviceaccounts, and services. Below is an example clusterrole with these minimum privileges.
apiVersion: rbac.authorization.k8s.io/v1 kind: ClusterRole metadata: name: netapp-kubernetes-monitoring-operator-installer-role rules: - apiGroups: - "" resources: - services - serviceaccounts - secrets - namespaces verbs: - get - list - create - patch - update - delete - apiGroups: - rbac.authorization.k8s.io resources: - roles - clusterroles - rolebindings - clusterrolebindings verbs: - get - list - create - patch - update - delete - escalate - bind - apiGroups: - apiextensions.k8s.io resources: - customresourcedefinitions verbs: - get - list - create - patch - update - delete - apiGroups: - apps resources: - deployments verbs: - get - list - create - patch - update - delete - apiGroups: - monitoring.netapp.com resources: - agents verbs: - get - list - create - patch - update - delete
