Creating a Report (Example)
Use the steps in this example to generate a simple report on physical capacity of storage and storage pools in a number of data centers.
Navigate to Menu > Content > Team Content > Reports
In the upper-right of the screen, select [New +]
Select Report
On the Templates tab, select Blank
The Source and Data tabs is displayed
Open Select a source +
Under Team content, open Packages
A list of available packages is displayed.
Choose Storage and Storage Pool Capacity
Select Open
The available styles for your report are displayed.
Select List
Add appropriate names for List and Query
Select OK
Expand Physical Capacity
Expand to the lowest level of Data Center
Drag Data Center to the Reporting palate.
Expand Capacity (MB)
Drag Capacity (MB) to the Reporting palate.
Drag Used Capacity (MB) to the Reporting palate.
Run the report by selecting an output type from the Run menu.
A report similar to the following is created:
