Data Infrastructure Insights
Capacity Efficiency Schema
Contributors netapp-alavoie
The Capacity Efficiency schema provides metrics on storage efficiency, including data reduction ratios and optimization opportunities. Use this schema to monitor and analyze the effectiveness of storage technologies like deduplication and compression.
Source: dwh_capacity_efficiency OData endpoint — Data Infrastructure Insights
Tables found: 3 | Associations: 2
Key Relationships Between Tables
efficiency_fact
Referenced (parent) table FK column Parent PK
date_dimension
dateTk
tk
storage_dimension
storageTk
tk
Tables & Fields
PKPrimary KeyFKForeign KeyNOT NULLRequired field
date_dimension
↑ top
Entity Set(s):date_dimension
Field Type Nullable Comment
tk
Int32
Yes
TK of the date object.
fullDate
DateTimeOffset
Yes
Date of the date object.
dayInMonth
Byte
Yes
Day of the month for the date object. The first day of the month has value 1.
dayInYear
Int32
Yes
Day in year of the date object. The first day of the year has value 1.
dateYear
Int32
Yes
Year of the date object.
yearLabel
String
Yes
Year formatted as String
monthNum
Byte
Yes
Month of the date object. January has value 1.
monthLabel
String
Yes
Month formatted as String
dayInWeekNum
Byte
Yes
Day of the week for the date object. Sunday has value 1.
quarter
Byte
Yes
Quarter of the date object. First quarter has value 1.
quarterLabel
String
Yes
Quarter formatted as String
dayInQuarter
Int32
Yes
Day in quarter of the date object. First day of the quarter has value 1.
repQuarter
Byte
Yes
Indicates whether this date is the first date available for its quarter.
repMonth
Byte
Yes
Indicates whether this date is the first date available for its month.
repWeek
Byte
Yes
Indicates whether this date is the first date available for its week.
repDay
Byte
Yes
Indicates whether this date is the first date available for its day.
repMonthOrLatest
Byte
Yes
Indicates whether this date is the repmonth or the latest. This flag is used by Datamarts which works on monthly reps. Only difference being for the current month it is the latest
sspFlag
Byte
Yes
Indicates whether this date is used in Storage and Storage Pool Datamart. It is true for month representatives and for the last number of days as defined in configuration.
latest
String
Yes
Indicates whether this date is the last date available in the table.
future
String
Yes
Indicates whether this date is a future date (projection) or regular one.
Nav Property Related Entity Cardinality / Join
efficiency_fact
efficiency_fact
many
efficiency_fact
↑ top
Entity Set(s):efficiency_fact
tk [PK]
Int32
Yes
TK of the fact.
dateTk [FK] →date_dimension.tk
Int32
Yes
TK of the date.
storageTk [FK] →storage_dimension.tk
Int32
Yes
TK of the storage where the capacity resides.
rawCapacityMB
Int64
Yes
Storage raw capacity in MB. 0 when technology is specified (not NULL).
backendCapacityMB
Int64
Yes
Total capacity of backend LUNs in a virtual array, in MB. 0 when technology is specified (not NULL).
storageTechnology
String
Yes
Storage efficiency and protection technology such as Dedupe, Thin Provisioning, Snapshot and RAID. NULL when representing raw and backend capacity of the storage (one row per storage) .
gainMB
Int64
Yes
Capacity gained by using the technology. 0 when technology is not specified (NULL).
lossMB
Int64
Yes
Capacity lost by using the technology. 0 when technology is not specified (NULL).
potentialGainMB
Int64
Yes
Potential capacity to gain by using the technology to the full extent. 0 when technology is not specified (NULL).
potentialLossMB
Int64
Yes
Potential capacity to loss by using the technology to the full extent. 0 when technology is not specified (NULL).
storage_dimension
storage_dimension
one JOIN:storageTk=storage_dimension.tk
date_dimension
date_dimension
one JOIN:dateTk=date_dimension.tk
storage_dimension
↑ top
Entity Set(s):storage_dimension
tk
Int32
Yes
TK of this storage array row.
name
String
Yes
Name of the storage array.
identifier
String
Yes
Identifier of the device.
ip
String
Yes
IP address of the storage array.
model
String
Yes
Model of the storage array.
manufacturer
String
Yes
Manufacturer of the storage array.
serialNumber
String
Yes
Serial number for the storage array.
microcodeVersion
String
Yes
Version of the firmware running on the storage array.
family
String
Yes
Family name of the storage array (e.g. Clariion, Symmetrix etc).
url
String
Yes
Url to this storage in Insight Server.
id
Int64
Yes
GUID of the storage array in dwh_inventory.storage.
latest
String
Yes
Indicates whether this row is the latest one for this storage.
dateTk
Int32
Yes
TK of the date in which this stroage array row was created.
dataCenter
String
Yes
dataCenter annotation value assigned to dwh_dimensions.storage_dimension
efficiency_fact
efficiency_fact
many
