File System Utilization Schema
The File System Utilization schema tracks storage consumption and usage patterns across file systems, hosts, and compute resources. Use this schema to identify capacity hotspots and optimize storage allocation at the file system level.
Source: dwh_fs_util OData endpoint — Data Infrastructure Insights
Tables found: 8 | Associations: 7
Key Relationships Between Tables
fs_util_fact
| Referenced (parent) table | FK column | Parent PK |
computeResourceTk |
tk |
dateTk |
tk |
fsTk |
tk |
hostTk |
tk |
storageTk |
tk |
tierTk |
tk |
vmTk |
tk |
Tables & Fields
PKPrimary KeyFKForeign KeyNOT NULLRequired field
compute_resource_dimension
↑ top
Entity Set(s):compute_resource_dimension
| Field | Type | Nullable | Comment |
tk |
Int32 |
Yes |
TK of this compute resource row. |
identifier |
String |
Yes |
Natural identifier of the compute resource. |
name |
String |
Yes |
name of the compute resource. |
type |
String |
Yes |
resource type. |
domain |
String |
Yes |
domain of compute resource. |
ip |
String |
Yes |
Comma separated list of IP addresses of the compute resource. |
os |
String |
Yes |
Operating system running on the compute resource. |
id |
Int64 |
Yes |
GUID of the compute resource in dwh_inventory.compute_resource |
latest |
String |
Yes |
Indicates whether this row is the latest one for this compute resource. |
dateTk |
Int32 |
Yes |
TK of the date in which this compute resource row was created. |
Navigation Properties (Joins)
| Nav Property | Related Entity | Cardinality / Join |
fs_util_fact |
many |
date_dimension
↑ top
Entity Set(s):date_dimension
tk |
Int32 |
Yes |
TK of the date object. |
fullDate |
DateTimeOffset |
Yes |
Date of the date object. |
dayInMonth |
Byte |
Yes |
Day of the month for the date object. The first day of the month has value 1. |
dayInYear |
Int32 |
Yes |
Day in year of the date object. The first day of the year has value 1. |
dateYear |
Int32 |
Yes |
Year of the date object. |
yearLabel |
String |
Yes |
Year formatted as String |
monthNum |
Byte |
Yes |
Month of the date object. January has value 1. |
monthLabel |
String |
Yes |
Month formatted as String |
dayInWeekNum |
Byte |
Yes |
Day of the week for the date object. Sunday has value 1. |
quarter |
Byte |
Yes |
Quarter of the date object. First quarter has value 1. |
quarterLabel |
String |
Yes |
Quarter formatted as String |
dayInQuarter |
Int32 |
Yes |
Day in quarter of the date object. First day of the quarter has value 1. |
repQuarter |
Byte |
Yes |
Indicates whether this date is the first date available for its quarter. |
repMonth |
Byte |
Yes |
Indicates whether this date is the first date available for its month. |
repWeek |
Byte |
Yes |
Indicates whether this date is the first date available for its week. |
repDay |
Byte |
Yes |
Indicates whether this date is the first date available for its day. |
repMonthOrLatest |
Byte |
Yes |
Indicates whether this date is the repmonth or the latest. This flag is used by Datamarts which works on monthly reps. Only difference being for the current month it is the latest |
sspFlag |
Byte |
Yes |
Indicates whether this date is used in Storage and Storage Pool Datamart. It is true for month representatives and for the last number of days as defined in configuration. |
latest |
String |
Yes |
Indicates whether this date is the last date available in the table. |
future |
String |
Yes |
Indicates whether this date is a future date (projection) or regular one. |
fs_util_fact |
many |
file_system_dimension
↑ top
Entity Set(s):file_system_dimension
tk |
Int32 |
Yes |
TK of the dimension. |
computeResourceIdentifier |
String |
Yes |
Identifier of the compute resource. Part of the natural key. |
name |
String |
Yes |
Mounting point or drive latter. Part of the natural key. |
location |
String |
Yes |
Indicates where the data is kept and how it is accessed. For example: local, SAN, NAS. Will be set to null if the location is unknown. |
hardwareId |
String |
Yes |
Host specific identifier. Will be set to null if unknown. |
type |
String |
Yes |
File system type. For example: NTFS, FAT, UFS, UDF, ZFS, ISO 9660, VXFS etc. Will be set to null if unknown. |
id |
Int64 |
Yes |
GUID of the file-system in dwh_inventory.file_system. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this file-system. |
dateTk |
Int32 |
Yes |
TK of the date in which this file-system row was created. |
fs_util_fact |
many |
fs_util_fact
↑ top
Entity Set(s):fs_util_fact
tk [PK] |
Int32 |
Yes |
TK of the fact. |
dateTk [FK] →date_dimension.tk |
Int32 |
Yes |
TK of the date. |
hostTk [FK] →host_dimension.tk |
Int32 |
Yes |
TK of the host. |
vmTk [FK] →vm_dimension.tk |
Int32 |
Yes |
TK of the vm. |
computeResourceTk [FK] →compute_resource_dimension.tk |
Int32 |
Yes |
TK of the computeResource. |
fsTk [FK] →file_system_dimension.tk |
Int32 |
Yes |
TK of the file system. |
storageTk [FK] →storage_dimension.tk |
Int32 |
Yes |
TK of the storage. |
tierTk [FK] →tier_dimension.tk |
Int32 |
Yes |
TK of the tier. |
sizeMB |
Int64 |
Yes |
Size of the file system in MB. |
usedMB |
Int64 |
Yes |
Amount of file-system capacity that is used and is not available. |
file_system_dimension |
one JOIN:fsTk=file_system_dimension.tk |
storage_dimension |
one JOIN:storageTk=storage_dimension.tk |
tier_dimension |
one JOIN:tierTk=tier_dimension.tk |
compute_resource_dimension |
one JOIN:computeResourceTk=compute_resource_dimension.tk |
host_dimension |
one JOIN:hostTk=host_dimension.tk |
vm_dimension |
one JOIN:vmTk=vm_dimension.tk |
date_dimension |
one JOIN:dateTk=date_dimension.tk |
host_dimension
↑ top
Entity Set(s):host_dimension
tk |
Int32 |
Yes |
TK of this host row. |
name |
String |
Yes |
Name of the host. |
identifier |
String |
Yes |
Identifier of the device. |
ip |
String |
Yes |
Comma separated list of IP addresses of the host. |
os |
String |
Yes |
Operating system running on the host. |
model |
String |
Yes |
Model number. |
manufacturer |
String |
Yes |
Manufacturer of the host. |
url |
String |
Yes |
Url to this host in Insight Server. |
id |
Int64 |
Yes |
GUID of the host in dwh_inventory.host. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this host. |
dateTk |
Int32 |
Yes |
TK of the date in which this host row was created. |
dataCenter |
String |
Yes |
dataCenter annotation value assigned to dwh_dimensions.host_dimension |
fs_util_fact |
many |
storage_dimension
↑ top
Entity Set(s):storage_dimension
tk |
Int32 |
Yes |
TK of this storage array row. |
name |
String |
Yes |
Name of the storage array. |
identifier |
String |
Yes |
ip |
String |
Yes |
IP address of the storage array. |
model |
String |
Yes |
Model of the storage array. |
manufacturer |
String |
Yes |
Manufacturer of the storage array. |
serialNumber |
String |
Yes |
Serial number for the storage array. |
microcodeVersion |
String |
Yes |
Version of the firmware running on the storage array. |
family |
String |
Yes |
Family name of the storage array (e.g. Clariion, Symmetrix etc). |
url |
String |
Yes |
Url to this storage in Insight Server. |
id |
Int64 |
Yes |
GUID of the storage array in dwh_inventory.storage. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this storage. |
dateTk |
Int32 |
Yes |
TK of the date in which this stroage array row was created. |
dataCenter |
String |
Yes |
dataCenter annotation value assigned to dwh_dimensions.storage_dimension |
fs_util_fact |
many |
tier_dimension
↑ top
Entity Set(s):tier_dimension
tk |
Int32 |
Yes |
TK of this tier row. |
name |
String |
Yes |
Identifying name for the tier. |
sequence |
Int32 |
Yes |
Sequencial number of the tier as defined in dwh_inventory.annotation_value. |
cost |
Double |
Yes |
Cost associated with this tier. |
id |
Int64 |
Yes |
GUID of the tier in dwh_inventory.annotation_value. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this tier. |
dateTk |
Int32 |
Yes |
TK of the date in which this tier row was created. |
fs_util_fact |
many |
vm_dimension
↑ top
Entity Set(s):vm_dimension
tk |
Int32 |
Yes |
TK of this virtual machine row. |
name |
String |
Yes |
Name of the virtual machine. |
naturalKey |
String |
Yes |
Natural identifier of the virtual machine. |
os |
String |
Yes |
Guest operating system. |
virtualCenterIp |
String |
Yes |
IP address of virtual center of the virtual machine. |
ips |
String |
Yes |
Comma separated list of IP addresses of the virtual machine. |
url |
String |
Yes |
Url to this virtual machine in Insight Server. |
id |
Int64 |
Yes |
GUID of the virtual machine in dwh_inventory.hv_virtual_machine |
latest |
String |
Yes |
Indicates whether this row is the latest one for this virtual machine. |
dateTk |
Int32 |
Yes |
TK of the date in which this virtual machine row was created. |
fs_util_fact |
many |
