Ports Schema
The Ports schema contains network port and switch data, including port connectivity, status, and relationships to connected devices. Use this schema to analyze network topology and fabric health within your storage infrastructure.
Source: dwh_ports OData endpoint — Data Infrastructure Insights
Tables found: 7 | Associations: 4
Key Relationships Between Tables
ports_fact
| Referenced (parent) table | FK column | Parent PK |
connectedDeviceTk |
tk |
dateTk |
tk |
portTk |
tk |
switchTk |
tk |
Tables & Fields
PKPrimary KeyFKForeign KeyNOT NULLRequired field
cardinals
↑ top
Entity Set(s):cardinals
| Field | Type | Nullable | Comment |
digit |
Int32 |
Yes |
A number between 0 and 99. |
connected_device_dimension
↑ top
Entity Set(s):connected_device_dimension
tk [PK] |
Int32 |
Yes |
TK of the device. |
name |
String |
Yes |
Name of the device. |
manufacturer |
String |
Yes |
Manufacturer of the device. |
model |
String |
Yes |
Model of the device. |
type |
String |
Yes |
Type of the device. |
firmware |
String |
Yes |
Firmware version running on the device. |
id |
Int64 |
Yes |
The ID of the device |
latest |
String |
Yes |
Indicates whether this row is the latest one for this device. |
Navigation Properties (Joins)
| Nav Property | Related Entity | Cardinality / Join |
ports_fact |
many |
date_dimension
↑ top
Entity Set(s):date_dimension
tk |
Int32 |
Yes |
TK of the date object. |
fullDate |
DateTimeOffset |
Yes |
Date of the date object. |
dayInMonth |
Byte |
Yes |
Day of the month for the date object. The first day of the month has value 1. |
dayInYear |
Int32 |
Yes |
Day in year of the date object. The first day of the year has value 1. |
dateYear |
Int32 |
Yes |
Year of the date object. |
yearLabel |
String |
Yes |
Year formatted as String |
monthNum |
Byte |
Yes |
Month of the date object. January has value 1. |
monthLabel |
String |
Yes |
Month formatted as String |
dayInWeekNum |
Byte |
Yes |
Day of the week for the date object. Sunday has value 1. |
quarter |
Byte |
Yes |
Quarter of the date object. First quarter has value 1. |
quarterLabel |
String |
Yes |
Quarter formatted as String |
dayInQuarter |
Int32 |
Yes |
Day in quarter of the date object. First day of the quarter has value 1. |
repQuarter |
Byte |
Yes |
Indicates whether this date is the first date available for its quarter. |
repMonth |
Byte |
Yes |
Indicates whether this date is the first date available for its month. |
repWeek |
Byte |
Yes |
Indicates whether this date is the first date available for its week. |
repDay |
Byte |
Yes |
Indicates whether this date is the first date available for its day. |
repMonthOrLatest |
Byte |
Yes |
Indicates whether this date is the repmonth or the latest. This flag is used by Datamarts which works on monthly reps. Only difference being for the current month it is the latest |
sspFlag |
Byte |
Yes |
Indicates whether this date is used in Storage and Storage Pool Datamart. It is true for month representatives and for the last number of days as defined in configuration. |
latest |
String |
Yes |
Indicates whether this date is the last date available in the table. |
future |
String |
Yes |
Indicates whether this date is a future date (projection) or regular one. |
ports_fact |
many |
port_dimension
↑ top
Entity Set(s):port_dimension
tk |
Int32 |
Yes |
TK of this port row. |
wwn |
String |
Yes |
WWN of the port. |
name |
String |
Yes |
Name of the port. |
gbicType |
String |
Yes |
Type of GBIC (Gigabit Interface Converter) used for the port. |
type |
String |
Yes |
Port type, typically used to identify the protocol used to communicate with the other device, taken from the device itself: F-port, E-port, and so forth. |
speed |
String |
Yes |
Speed of the port, in Gbps. |
isGenerated |
String |
Yes |
Indication whether this is a generated wwn (if we do not know the real wwn). |
url |
String |
Yes |
Url to this port in Insight Server. |
id |
Int64 |
Yes |
GUID of the port in dwh_inventory.switch_port. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this port. |
dateTk |
Int32 |
Yes |
TK of the date in which the port row was created. |
ports_fact |
many |
ports_fact
↑ top
Entity Set(s):ports_fact
tk [PK] |
Int32 |
Yes |
TK of the fact. |
dateTk [FK] →date_dimension.tk |
Int32 |
Yes |
TK of the date. |
switchTk [FK] →switch_dimension.tk |
Int32 |
Yes |
TK of the switch containing the port. |
connectedDeviceTk [FK] →connected_device_dimension.tk |
Int32 |
Yes |
TK of the device that is connected to the port. |
portTk [FK] →port_dimension.tk |
Int32 |
Yes |
TK of the port. |
fabric |
String |
Yes |
Name or WWN for the fabric (or VSAN) on which the port is configured to operate. |
speed |
String |
Yes |
connectivityType |
String |
Yes |
Type of the connected device. |
type |
String |
Yes |
status |
String |
Yes |
Status of the port. Possible values are OK, NOT_LICENSED, ERROR, INACTIVE and UNKNOWN |
connected_device_dimension |
one JOIN:connectedDeviceTk=connected_device_dimension.tk |
port_dimension |
one JOIN:portTk=port_dimension.tk |
date_dimension |
one JOIN:dateTk=date_dimension.tk |
switch_dimension |
one JOIN:switchTk=switch_dimension.tk |
ports_fact_current
↑ top
Entity Set(s):ports_fact_current
tk |
Int32 |
Yes |
TK of the fact. |
dateTk |
Int32 |
Yes |
TK of the date. |
switchTk |
Int32 |
Yes |
connectedDeviceTk |
Int32 |
Yes |
portTk |
Int32 |
Yes |
TK of the port. |
fabric |
String |
Yes |
speed |
String |
Yes |
connectivityType |
String |
Yes |
type |
String |
Yes |
status |
String |
Yes |
switch_dimension
↑ top
Entity Set(s):switch_dimension
tk |
Int32 |
Yes |
TK of this switch row. |
wwn |
String |
Yes |
WWN of the switch. |
name |
String |
Yes |
Name of the switch. |
identifier |
String |
Yes |
Identifier of the device. |
ip |
String |
Yes |
IP address of the switch. |
model |
String |
Yes |
Model of the switch. |
manufacturer |
String |
Yes |
Manufacturer of the switch. |
firmware |
String |
Yes |
Firmware version running on the switch. |
serialNumber |
String |
Yes |
Serial number of the switch. |
npv |
String |
Yes |
Indication whether this is an NPV switch. |
isGenerated |
String |
Yes |
Indication whether this switch does not correspond to a physical device. It is used to model one to many port connectivity. |
type |
String |
Yes |
Switch type. |
url |
String |
Yes |
Url to this switch in Insight Server. |
id |
Int64 |
Yes |
GUID of the switch in dwh_inventory.switch. |
latest |
String |
Yes |
Indicates whether this row is the latest one for this switch. |
dateTk |
Int32 |
Yes |
TK of the date in which this switch row was created. |
dataCenter |
String |
Yes |
dataCenter annotation value assigned to dwh_dimensions.switch_dimension |
switchLevel |
String |
Yes |
switchLevel annotation value assigned to dwh_dimensions.switch_dimension |
ports_fact |
many |
