Data Infrastructure Insights Reporting User Roles
If you have Data Infrastructure Insights Premium Edition with Reporting, every Data Infrastructure Insights user on your tenant also has a Single Sign-On (SSO) login to the Reporting application (i.e. Cognos). Simply click the Reports link in the menu and you will automatically be logged in to Reporting.
Your user role in Data Infrastructure Insights determines your Reporting user role:
Data Infrastructure Insights Role |
Reporting Role |
Reporting Permissions |
Guest |
Consumer |
Can view, schedule, and run reports and set personal preferences such as those for languages and time zones. Consumers cannot create reports or perform administrative tasks. |
User |
Author |
Can perform all Consumer functions as well as create and manage reports and dashboards. |
Administrator |
Administrator |
Can perform all Author functions as well as all administrative tasks such as configuration of reports and the shutdown and restart of reporting tasks. |
The following table shows the functions available to each Reporting role.
Feature |
Consumer |
Author |
Administrator |
View reports in the Team Content tab |
Yes |
Yes |
Yes |
Run reports |
Yes |
Yes |
Yes |
Schedule reports |
Yes |
Yes |
Yes |
Upload external files |
No |
Yes |
Yes |
Create Jobs |
No |
Yes |
Yes |
Create stories |
No |
Yes |
Yes |
Create reports |
No |
Yes |
Yes |
Create Packages and Data Modules |
No |
Yes |
Yes |
Perform administrative tasks |
No |
No |
Yes |
Add/Edit HTML Item |
No |
No |
Yes |
Run report with HTML Item |
Yes |
Yes |
Yes |
Add/Edit Custom SQL |
No |
No |
Yes |
Run reports with Custom SQL |
Yes |
Yes |
Yes |
Reporting Administration
The previous Reporting Administration Console is no longer available. Use Manage for reporting administration.
In Data Infrastructure Insights, open Reports.
Select Menu > Manage.
From Manage, a Reporting administrator can configure reports and work with current, past, and upcoming reporting activities.
To open run details for a completed activity:
Select Menu > Manage > Activities > Past.
On the activity, open the three-dots menu.
Select Run Details.
For more information, see this KB Article.
Setting Reporting (Cognos) email preferences
If you change your user email preferences within Data Infrastructure Insights Reporting (i.e. the Cognos application), those preferences are active only for the current session. Logging out of Cognos and back in again will reset your email preferences. |
What steps should I take to prepare my existing environment for enabling SSO?
To ensure your reports are retained, migrate all reports from My Content to Team Content using the following steps. You must do this prior to enabling SSO on your tenant:
Navigate to Menu > Content
Create a new folder in Team Content
If multiple users have been created, please create a separate folder for each user to avoid overwriting reports with duplicate names
Navigate to My Content
Select all of the reports you wish to retain.
In the upper right corner of the menu, select "Copy or move"
Navigate to the newly created folder in Team Content
Paste the reports to the newly created folder using the "Copy to" or "Move to" buttons
Once SSO is enabled for Cognos, log into Data Infrastructure Insights with the email address used to create your account.
Navigate to the Team Content folder within Cognos, and Copy or Move the previously saved reports back to My Content.
