ActiveMQ Data Collector
Data Infrastructure Insights uses this data collector to gather metrics from ActiveMQ.
Installation
From Observability > Collectors, click +Data Collector. Choose ActiveMQ.
Select the Operating System or Platform on which the Telegraf agent is installed.
If you haven't already installed an Agent for collection, or you wish to install an Agent for a different Operating System or Platform, click Show Instructions to expand the Agent installation instructions.
Select the Agent Access Key for use with this data collector. You can add a new Agent Access Key by clicking the + Agent Access Key button. Best practice: Use a different Agent Access Key only when you want to group data collectors, for example, by OS/Platform.
Follow the configuration steps to configure the data collector. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Setup
Information may be found in the ActiveMQ documentation
Objects and Counters
The following objects and their counters are collected:
| Object: | Identifiers: | Attributes: | Datapoints: |
ActiveMQ Queue |
Namespace |
Node Name |
Consumer Count |
ActiveMQ Subscriber |
Client ID |
Is Active |
Dequeue Count |
ActiveMQ Topic |
Topic |
Node Name |
Consumer Count |
Troubleshooting
Additional information may be found from the Support page.
