Data Infrastructure Insights
Consul Data Collector
Contributors netapp-alavoie dgracenetapp
Data Infrastructure Insights uses this data collector to gather metrics from Consul.
Note This collector is deprecated. It will no longer be available starting January 2027.
Installation
  1. From Observability > Collectors, click +Data Collector. Choose Consul.
    If you haven't configured an Agent for collection, you are prompted to install an agent on your tenant.
    If you have an agent already configured, select the appropriate Operating System or Platform and click Continue.
  2. Follow the instructions in the Consul Configuration screen to configure the data collector. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Setup
Information may be found in the Consul documentation.
Objects and Counters for consul
The following objects and their counters are collected:
Object: Identifiers: Attributes: Datapoints:
Consul
Namespace
Check ID
Service Node
Node IP
Node OS
Node UUID
Node Name
Service Name
Check Name
Service ID
Status
Critical
Passing
Warning
Troubleshooting
Additional information may be found from the Support page.
