Data Infrastructure Insights
Couchbase Data Collector
Contributors netapp-alavoie
Data Infrastructure Insights uses this data collector to gather metrics from Couchbase.
Note This collector is deprecated. It will no longer be available starting January 2027.
Installation
  1. From Observability > Collectors, click +Data Collector. Choose Couchbase.
    Select the Operating System or Platform on which the Telegraf agent is installed.
  2. If you haven't already installed an Agent for collection, or you wish to install an Agent for a different Operating System or Platform, click Show Instructions to expand the Agent installation instructions.
  3. Select the Agent Access Key for use with this data collector. You can add a new Agent Access Key by clicking the + Agent Access Key button. Best practice: Use a different Agent Access Key only when you want to group data collectors, for example, by OS/Platform.
  4. Follow the configuration steps to configure the data collector. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Couchbase configuration
Setup
Information may be found in the Couchbase documentation.
Objects and Counters
The following objects and their counters are collected:
Object: Identifiers: Attributes: Datapoints:
Couchbase Node
Namespace
Cluster
Couchbase Node Hostname
Node Name
Node IP
Memory Free
Memory Total
Couchbase Bucket
Namespace
Bucket
Cluster
Node Name
Node IP
Data Used
Data Fetches
Disk Used
Item Count
Memory Used
Operations Per Second
Quota Used
Troubleshooting
Additional information may be found from the Support page.
