Data Infrastructure Insights
Elasticsearch Data Collector
Contributors netapp-alavoie dgracenetapp
Data Infrastructure Insights uses this data collector to gather metrics from Elasticsearch.
Note This collector is deprecated. It will no longer be available starting January 2027.
  1. From Observability > Collectors, click +Data Collector. Choose Elasticsearch.
    Select the Operating System or Platform on which the Telegraf agent is installed.
  2. If you haven't already installed an Agent for collection, or you wish to install an Agent for a different Operating System or Platform, click Show Instructions to expand the Agent installation instructions.
  3. Select the Agent Access Key for use with this data collector. You can add a new Agent Access Key by clicking the + Agent Access Key button. Best practice: Use a different Agent Access Key only when you want to group data collectors, for example, by OS/Platform.
  4. Follow the configuration steps to configure the data collector. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Elasticsearch configuration
Setup
Information may be found in the Elasticsearch documentation.
Objects and Counters
The following objects and their counters are collected:
Object: Identifiers: Attributes:
Elasticsearch Cluster
Namespace
Cluster
Node IP
Node Name
Cluster Status
Elasticsearch Node
Namespace
Cluster
ES Node ID
ES Node IP
ES Node
Zone ID
Troubleshooting
Additional information may be found from the Support page.
