The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Identifying inactive devices
Creating your file...
Your file is ready
Identifying the assets you have and who’s using them is critical to “right-sizing” and freeing up unused infrastructure. You can easily reallocate or decommission underused resources and avoid unnecessary purchases.
Use the following steps to identify inactive assets.
Steps
Navigate to Observability > Explore → +New Metric Query.
Select Storage from the drop down.
Click the gear and add isActive as a column.
Rows showing a Check are active. "X" indicates inactive devices.
To remove inactive devices, simply select the devices to remove and in the Bulk Actions drop-down, select Delete Inactive Devices.
