Data Infrastructure Insights
Modifying or Deleting a Query
Contributors netapp-alavoie
Manage your queries effectively by modifying search criteria, adding or removing columns, and choosing from flexible save options. Update existing queries, create new versions, or delete queries that are no longer needed to keep your query library organized and current.
Modifying a Query
Steps
  1. Click Explore and select All Metric Queries.
    The Queries page is displayed.
  2. Click the query name
  3. To add a criteria to the query, click Columns icon and select a metric or attribute from the list.
When you have made all necessary changes, do one of the following:
  • Click the Save button to save the query with the name that was used initially.
  • Click the drop-down next to the Save button and select Save As to save the query with another name. This does not overwrite the original query.
  • Click the drop-down next to the Save button and select Rename to change the query name that you had used initially. This overwrites the original query.
  • Click the drop-down next to the Save button and select Discard Changes to revert the query back to the last saved changes.
Deleting a Query
To delete a query, click Queries and select Show all queries, and do one of the following:
  1. Click on the "three dot" menu to the right of the query and click Delete.
  2. Click on the query name and select Delete from the Save drop-down menu.
