Workload Security Webhook Example for Slack
Webhooks allow users to send alert notifications to various applications using a customized webhook channel. This page provides an example for setting up webhooks for Slack.
This page refers to third-party instructions, which are subject to change. Refer to the Slack documentation for the most up-to-date information.
Slack Example
Go to https://api.slack.com/apps and Create a new App. Give it a meaningful name and select a Workspace.
Go to Incoming Webhooks, click on Activate Incoming Webhooks, select Add New Webhook, and select the Channel on which to Post.
Copy the Webhook URL. This URL will be given when creating a Workload Security webhook.
Create Workload Security Slack Webhook
Navigate to Admin > Notifications and select the Workload Security Webhooks tab. Select + Webhook to create a new webhook.
Give the webhook a meaningful name.
In the Template Type dropdown, select Slack.
Paste the URL copied from above.
Notifications via webhook
To notify on events via webhook, navigate to Workload Security > Policies. Click on +Attack Policy or +Warning Policy.
Enter a meaningful policy name.
Select required Attack Type(s), Devices to which the policy should be attached, and required Actions.
Under the Webhooks Notifications dropdown, select the required webhooks. Save the policy.
Note: Webhooks can also be attached to existing policies by editing them.
