Data Infrastructure Insights
Workload Security Webhook Example for Microsoft Teams
Contributors netapp-alavoie
Webhooks allow users to send alert notifications to various applications using a customized webhook channel. This page provides an example for setting up webhooks for Teams.
Note This page refers to third-party instructions, which are subject to change. Refer to the Teams documentation for the most up-to-date information.
Teams Setup:
  1. In Teams, select the kebab, and search for Incoming Webhook.
    Incoming Webhook in Teams
  2. Select Add to a Team > Select a Team > Setup a Connector.
  3. Copy the Webhook URL. You will need to paste this into the Workload Security webhook configuration.
Create Workload Security Teams Webhook:
  1. Navigate to Admin > Notifications and select the “Workload Security Webhooks tab. Select + Webhook to create a new webhook.
  2. Give the webhook a meaningful Name.
  3. In the Template Type drop-down, select Teams.
    Workload Security teams webhook example
  4. Paste the URL from above into the URL field.
Steps for creating Teams notification with Adaptive Card template
  1. Replace the message body with the following template:
      "type": "message",
      "attachments": [
          "contentType": "application/vnd.microsoft.card.adaptive",
          "content": {
            "$schema": "http://adaptivecards.io/schemas/adaptive-card.json",
            "type": "AdaptiveCard",
            "version": "1.2",
            "body": [
                "type": "TextBlock",
                "text": "%%severity%% Alert: %%synopsis%%",
                "wrap": true,
                "weight": "Bolder",
                "size": "Large"
                "text": "%%detected%%",
                "wrap": true,
                "isSubtle": true,
                "spacing": "Small"
                "type": "FactSet",
                "facts": [
                    "title": "User",
                    "value": "%%userName%%"
                    "title": "Attack/Abnormal Behavior",
                    "value": "%%type%%"
                    "title": "Action taken",
                    "value": "%%actionTaken%%"
                    "title": "Files encrypted",
                    "value": "%%filesEncrypted%%"
                    "title": "Encrypted files suffix",
                    "value": "%%encryptedFilesSuffix%%"
                    "title": "Files deleted",
                    "value": "%%filesDeleted%%"
                    "title": "Activity Change Rate",
                    "value": "%%changePercentage%%"
                    "title": "Severity",
                    "value": "%%severity%%"
                    "title": "Status",
                    "value": "%%status%%"
                    "title": "Notes",
                    "value": "%%note%%"
            "actions": [
                "type": "Action.OpenUrl",
                "title": "View Details",
                "url": "https://%%cloudInsightsHostname%%/%%alertDetailsPageUrl%%"
  2. If you are using Power Automate Flows, query params in the URL are in encoded format. You must decode the URL before entering.
  3. Click "Test Webhook" to ensure there are no errors.
  4. Save the webhook.
Notifications via Webhook
To notify on events via webhook, navigate to Workload Security > Policies. Select +Attack Policy or +Warning Policy.
  • Enter a meaningful policy name.
  • Select required Attack Type(s), Devices to which policy should be attached, and required Actions.
  • Under the Webhooks Notifications dropdown, select the required Teams webhooks. Save the policy.
Note: Webhooks can also be attached to existing policies by editing them.
Add attack policy dialog showing webhook
