Configure Bulk Migrate in NetApp Data Migrator
Use the Bulk Migrate features in NetApp Data Migrator to transfer large volumes of data from a source to a destination location.
Step 1: Configure Bulk Migrate in NetApp Data Migrator
You need to define the servers for Bulk Migrate before you can use the Bulk Migrate features.
Log in to NetApp Data Migrator.
Select Storage Servers > File Servers.
Select the File Server Name for which you want to create the job.
Select Bulk Migrate.
Step 2: Add source and destination mappings
Add source and destination mappings to specify the source export paths and destination export paths for your migration.
Select the export path in the source that you want to migrate.
Optionally, select Add Source Directory if you want to perform a migration at the directory level.
After you select Add Source Directory, the directory explorer view appears. This view shows the list of directories at the root level. You can either navigate to the required directory or directly copy and paste the path of the required directory into the search bar of the explorer window to navigate to that folder.
After you select the source directory, select the destination file server and destination export path.
Optionally, select the directory in the destination export path.
If you don't select a directory in the destination export path, the migration takes place at the root level of the selected export path.
After you select the source and destination paths, select Add Mapping to add the selected mapping. You can create multiple mappings for different export paths and directories.
NetApp Data Migrator prevents you from selecting a mapping which has a parent or child connection with an existing mapping. This avoids conflicts during the migration.
Optionally, delete or edit a mapping by selecting the Edit or Delete option.
After you add the mappings, select Proceed.
Step 3: Customize the Bulk Migrate job
You can select various settings from the Options page to customize your Bulk Migrate job, according to your needs.
| Option | Description |
Convert inherited permissions to explicit |
When you enable this option, any permissions inherited from the source are written as explicit permissions on the destination during SMB migrations at the directory level. |
Excluded Path Patterns |
Defines the specific file paths or directories to be excluded from processing. This helps to optimize storage and performance by skipping unnecessary files.
Incremental Sync Schedule |
Configures how often data syncs incrementally. This ensures that only the changes since the last sync are updated, which improves migration efficiency and reduces processing time.
Migrate File |
Selects the files to migrate based on their last modified time.
Preserve a-time (Access Time) |
Retains the original file access timestamp, instead of updating it to the migration time. |
Preserve permissions |
Retains the original source file and directory permissions on a destination.
Skip Files modified in last |
Specifies files from a time window (in minutes, hours, or days) to exclude from your migration. This helps prevent data inconsistency by ensuring that actively edited files are not transferred mid-update. |
Upload GID / UID mapping |
Uploads a Group ID (GID) or User ID (UID) mapping file to maintain correct file ownership during migration. The uploaded file must follow the format specified in the template provided.
Upload SID mapping |
Uploads a Security Identifier (SID) mapping file. SID mapping ensures that user and group permissions are retained accurately when migrating or syncing files between systems. The uploaded file must follow the format specified in the template provided for you to download.
After selecting your options, select Proceed to open the Review and Submit page.
Step 4: Review and submit
Verify your settings, then proceed with a bulk migration job.
View the Precheck Status of your job. Ensure that the source path contains the correct data and confirm that the destination path has sufficient storage and access permissions.
Select Submit to create a new migration job.
The Bulk Migrate job has been created confirmation message appears.
Select the View Job Listing link next to the notification message to open the Job Config List page where your new job is listed.
