Decide whether to use NetApp Data Migrator
Use the decision matrix to determine whether to use NetApp Data Migrator or SnapMirror for your NFS and SMB data migration operations from an ONTAP on-premises storage system. For example, if you are migrating NFS and SMB files from an ONTAP on-premises source running ONTAP 9.12.1 to a Google Cloud NetApp Volumes Flex service destination, you should use NetApp Data Migrator.
NetApp Data Migrator does not support data migration to ONTAP on-premises storage system destinations. |
| On-premises or third-party storage system source | Amazon FSx for NetApp ONTAP | Azure NetApp Files hardware | Cloud Volumes ONTAP | Google Cloud NetApp Volumes hardware | Google Cloud NetApp Volumes Flex | Google Cloud NetApp Volumes Flex (VSA based) |
ONTAP on-premises Beginning with ONTAP 9.10.1 |
SnapMirror |
SnapMirror |
SnapMirror |
SnapMirror |
NetApp Data Migrator |
SnapMirror |
ONTAP on-premises For ONTAP 9.9.1 and earlier |
Non-NetApp storage systems and arrays |
Cloud Volumes ONTAP Beginning with ONTAP 9.10.1 |
SnapMirror |
SnapMirror |
SnapMirror |
SnapMirror |
SnapMirror |
Cloud Volumes ONTAP For ONTAP 9.9.1 and earlier |
Not applicable |
Not applicable |
Not applicable |
Migrating data without permissions |
Learn about SnapMirror volume replication
