NetApp Data Migrator
Known limitations for NetApp Data Migrator
Contributors netapp-pcarriga
NFS and SMB migration limitations and features that do not work or do not work well with this version are listed here. Read these limitations carefully.
NFS and SMB discovery and migration limitations
Description NFS SMB
Number of parallel jobs
4
2
Maximum number of files in a directory
1 million
1 million
Worker sizing
4 core CPU, 16 GB memory
16 core CPU, 64 GB memory
Control plane sizing
8 core CPU, 64 GB memory
Maximum number of files in an export path
20 million
20 million
Feature limitations
Description Limits
Active destination support
NetApp Data Migrator does not support an active destination (when a target storage is actively used or written before Cutover).
Case sensitive files
For SMB, NetApp Data Migrator migrates only one of the case-differing files created using NFS in a folder and errors out the other file. This occurs because SMB can't accept both files. You can run discovery using NFS to identify these case-sensitive files.
Network accessibility
NetApp recommends using NetApp Data Migrator in private networks.
NFSv4 ACLs
NetApp Data Migrator does not stamp access control lists (ACLs) with NFSv4, it only applies basic permissions in the destination. This behavior is similar to NFSv3.
Protocol migration - Type
Cross-protocol migration is not supported, for example, NFS to SMB.
Protocol migration - Version
Cross-version migration within the same protocol is not supported, for example, NFSv3 to NFSv4.
SMB permissions
NetApp Data Migrator does not support migration of SMB System Access Control List (SACL) (audit permissions).
SMB files with trailing spaces
When migrating over SMB, NetApp Data Migrator errors out files with names that contain trailing spaces because SMB does not permit these file names.
SMB special files
NetApp Data Migrator discovers redirects (symbolic links, hard links, junction points, Alternate Data Streams (ADS), and volume mount points) and reports them after discovery. Migration of ADS, sparse files, and SMB redirects is not supported.
Security
NetApp Data Migrator uses self-signed certificates to encrypt web traffic with SSL/TLS.
Sparse files
Sparse files become full-size files when they migrate, NetApp Data Migrator doesn't preserve sparsity. You need extra storage for these files.
System files
NetApp Data Migrator cannot migrate system-generated files that the source owns.
User interface
NetApp Data Migrator is optimized for Google Chrome and Firefox browsers using 1920 x 1080 screen resolution; mobile displays are not supported.
Windows worker deployment
The Windows worker must be part of the same root domain as the destination.
