Manage jobs and job runs in NetApp Data Migrator
Use job management features in NetApp Data Migrator to initiate and track your Discovery, Migration, and Cutover jobs and job runs.
Do not run Migration and Cutover jobs simultaneously. Ensure that only one job is active at a time. |
View Job Config List
The Job Config List page provides a comprehensive overview of all migration related jobs. Use this page to monitor and manage the status and progress of Discovery, Migration, and Cutover jobs.
Log in to NetApp Data Migrator.
Select Jobs > Job Config List.
The Jobs Listings table appears, which includes the following information:
Source: The location of source file server.
Destination: The destination file server and export path details for Migration jobs.
Protocol: The protocol used by the job (NFS or SMB).
Next Schedule: The next scheduled execution time (if applicable).
Runs: The number of times the job has been executed.
Type: The job type (Discovery, Migration, or Cutover).
Status: The current state of a job can be either Active or Inactive. Jobs that use manual export paths with an invalid or disabled status automatically become inactive. Refer to Add and manage file servers in NetApp Data Migrator for more details.
Updated On: Job update timestamp.
Jobs that use manual export paths or the export paths file are later re-uploaded. Any previously run jobs associated with a now invalid or disabled path automatically become inactive.
Select Filters to sort the jobs in the Jobs Listings table. You can choose a combination of filters based on the following options:
Source
Destination
Protocol
Type
Status
Select Clear all to remove filters already applied to your job listings.
Activate or deactivate a Job
From the Job Listings table, you can activate or deactivate a job.
Activate a job:
In the Job Listings table, select the action menu next to the job you want to activate.
Select Activate. The job status changes to Active.
Deactivate a job:
In the Job Listings table, select the action menu next to the job you want to deactivate.
Select Deactivate. The job status changes to Inactive, and execution stops until you reactivate the job.
Edit job configurations
Open the Job Details page for the job you want to edit.
Select View/Edit Configuration.
Edit the job configuration:
Discovery Job-
Add or remove Excluded Path Patterns
Schedule a job run
Migration Job-
Edit any job option
Add or remove mappings
Schedule a job run
Select Save. The new configuration affects future job runs.
Changing the configuration, for example, disabling preserve permissions, after baseline migration is completed might result in an inconsistent state during subsequent migrations. Instead of changing the configuration, you should delete the current job and start a new job. |
Re-run errored files and directories
If a migration job run completes with errors due to transient issues such as network timeouts or permission problems, you can use the retry feature to re-process only the failed items without re-running the entire migration.
In the Job Listings table, select the action menu next to the job that has failed items.
Select Details > Retry Recent Errors > Proceed with Retry to start the retry operation.
Delete a Job
In the Job Listings table, select the action menu next to the job you want to delete.
Select Delete > Delete.
You can only delete a job if there is no active run.
View Job Details
From the Job Config List page, you can access the Job Details page to view additional details about individual jobs, such as:
Job type (Discovery, Migration, or Cutover)
Number of files and directories discovered
Time elapsed
Data discovered
Job configuration
In the Job Listings table, select the action menu next to a job, then select Details.
View Job Run History
On the Job Details page, the Run History table provides you with the information about previous job runs and the job status.
The migration and discovery job status types include:
Ready: A job is scheduled to run.
Running: A job is in the running state.
Paused: A job run has been paused manually or by NetApp Data Migrator. For example, a job can have a paused status if a worker goes down while the job is running.
Completed: A job is complete.
Errored: A job run triggers a fatal error.
Failed: If a worker goes offline while a job is running, the job might enter a failed state.
The cutover job status types include:
Blocked: The job is waiting for a user response.
Rejected: The job has been reviewed and rejected by a user.
Approved: The job has been reviewed and approved by a user.
Stopped: The job has stopped running.
Manage Job Run operations
From the Job Details page, you can manage Start, Stop, Pause, and Resume operations for a job. Use the Pause feature to temporarily halt a running job, without canceling it. Then you can resume the job from the point where it was paused. This is a useful feature in scenarios where you need to free up system resources or troubleshoot issues without losing progress.
On the Job Details page, in the Run History table, select the action menu next to a running job.
Pause or resume a job run:
Select Pause.
To Resume the job run, select Resume.
The job status changes to Running and the job continues to run from the step where it was paused.
Stop or start a job run:
You can use the stop option to permanently terminate a job run that is in progress. This action is useful when a job run is no longer required. You cannot resume a job run that is stopped but you have the option to start a new job run from the beginning.
Select Stop.
The job run status changes to Stopped.
To start a new job run, select Adhoc Run.
The job run status changes to Running.
Access Job Run Details
From the Run History table, access the Job Run Details page where you can view additional details about your job runs.
On the Job Details page, in the Run History table, select the action menu next to a job run.
Select Details to view the Job Run Details page, which includes the following information:
Discovery/Migration: The job run type and status.
Files: The number of files found during the discovery process.
Directories: The number of directories found during the discovery process.
Elapsed Time: How long the discovery process took.
Data Discovered: The total size of discovered files.
Workers: The number of workers assigned to the job.
Tasks: The number of tasks being executed.
Task Status Indicators:
Pending: The number of Tasks waiting to be executed.
Running: The number of Tasks currently in progress.
Completed: The number of tasks that have successfully completed.
Errored: The number of tasks that encountered issues during execution.
Job Name: The name assigned to the job.
Source Path: The path to the file being used for data discovery.
Protocol: The protocol being used for discovery (NFS or SMB).
The lower right tile on the Job Run Details page lists the number of errors that occurred during migration (if any). Select View All to access the Errors page, where you can find more detailed information about these errors.
Generate detailed reports that provide you with insights into job execution metrics including file counts, status, errors, and execution time. You can use these reports for review or auditing purposes.
Select Discovery Report > Preview to view a histogram of job report data.
Select Download as CSV to export a report in CSV format, which you can analyze using a spreadsheet application.
Select Download as PDF . This option is ideal for document sharing.
Select View Logs to view or download the log files using Grafana.
View Migration Activity
The Migration Activity page shows the ten oldest files currently being migrated. It also shows the total number of files in progress and provides an option to download a CSV file containing a complete list of these files.
From the Run History table, select Job Run Details for a running job.
Select Migration Activity.
Generate a job error report
You can generate an error report for jobs with an Errored status or for a previous job run. An error report can help you to understand why an error occurred.
Generate an error report for jobs with an Errored status:
On the Job Details page, in the Errors pane, select View All.
Select Generate Error Report to download details about errors in the latest job run.
Generate an error report for a previous job run:
On the Job Details page, in the Run History table, select the action menu next to the job run for which you want to generate an error report.
Select Details.
On the Job Details page, in the Errors panel, select View All.
Select Generate Error Report to download details about errors in the job run you selected.
