Create and manage projects in NetApp Data Migrator
You can use the Projects tab in the NetApp Data Migrator control plane to create, edit, or switch between projects.
Create a project
App Admin users can create a new project in NetApp Data Migrator and assign users with defined roles to that project.
Log in to NetApp Data Migrator.
Select Settings > Projects to view a list of existing projects.
Select Add Project and a new window appears.
Enter your Project Name and Project Description (optional).
Add users to your project:
Select a User from the dropdown list.
Assign a Role to the user (App Admin, Project Admin, or Project Viewer).
Select +Add.
Select Save and Confirm.
Select Submit and a confirmation message appears, stating that the project has been successfully created.
Edit a project
You can quickly edit details about your project, if they need updating.
Select Settings in the top navigation bar.
Select the Projects tab to view a list of existing projects.
Select (⋮) next to the details of the project you want to edit, then select Edit Project from the dropdown menu.
Update the Project Name, Project Description, or add new users as required.
Select Submit to save the changes.
Switch between projects
If you are monitoring several projects at the same time, you can quickly switch between them.
Select the Project dropdown menu from the top navigation bar,
Select the current project name to open the Project Selection menu and a list of available projects appears.
Use the Search Projects bar to quickly find the project you want to switch to.
Select the checkbox next to the name of the project you want to switch to.
Select Switch to load the selected project.
