NetApp Data Migrator
Verify NFS and SMB networking access in NetApp Data Migrator
Contributors netapp-pcarriga
You need to ensure that the IP address and subnet for both the control plane and workers are allowed in the export policy on the storage system. This is required to support NFS and SMB migrations using NetApp Data Migrator.
Verify NFS access
For NFS, the control plane and worker nodes need permission to access the storage system as root clients.
Steps
  1. Perform a manual mount from a worker node to verify volume accessibility:
    sudo mount -t nfs <storage-ip>:/<volume-path> /mnt/test
    ls -la /mnt/test
  2. Ensure that root access is enabled by verifying that the export policy rule allows superuser access. If necessary, enable root access (no root squash) by modifying the export policy rule.
Verify SMB access
For SMB access, the control plane and worker nodes need permission to access the storage system using the SMB credentials. The SMB user must be part of the Backup operators and Administrators groups.
Step
    net use Z: \\<storage-ip>\<share> /user:<domain>\<username> <password>
