NetApp Data Migrator
Register for NetApp Data Migrator support
Contributors netapp-pcarriga
Register your NetApp Data Migrator product to access NetApp Support.
Steps
  1. On the NetApp Data Migrator home page, select Help (?) > About > Serial Number
  2. In the About NDM dialog box, record the NetApp Data Migrator instance ID.
    This is a 20-digit number, starting with 975.
  3. Go to the NetApp Support Site registration page.
  4. Select I am not a registered NetApp Customer.
  5. Fill in the required product registration details:
    1. Leave the NetApp Reference SN field blank.
    2. From the Product Line dropdown, select NDM.
    3. From the Billing Provider dropdown, select NetApp.
      Note There is no billing for this product.
    4. Enter the 20-digit NetApp Data Migrator instance ID in the NDM Serial # field.
    5. Complete the remaining required fields, then select Submit.
  6. After submission, you receive a registration confirmation email. Follow the instructions in the email to confirm the registration.
