Validate the control plane VM deployment for NetApp Data Migrator
Optionally validate the control plane VM deployment for NetApp Data Migrator.
Steps
Use SSH to connect to your control plane server:
sudo su - datamigrator -
Check the status of the boot service and logs:
sudo systemctl status boot-microk8s.serviceOptionally, check the boot service logs:
tail -10f /opt/datamigrator/logs/ndm-first-boot.logIf the setup is complete, you see
Datamigrator Application Setup Completein the logs. -
Verify that all the pods are up and running:
kubectl get pods -n datamigrator
What's next?
After validating the control plane and worker deployment, you can configure access for control plane and worker nodes.
