Discover KVM workloads in NetApp Backup and Recovery
Discover KVM hosts and virtual machines in NetApp Backup and Recovery so you can protect them with protection policies. Your KVM environment must be managed by a management platform such as Apache CloudStack before discovery.
Required NetApp Console role
Backup and Recovery super admin. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
Add a management platform, KVM host, and discover resources
Add management platform and KVM host information and let NetApp Backup and Recovery discover workloads.
After adding a storage system to NetApp Console, wait a few minutes before discovering resources. Discovering resources immediately after adding a storage system can cause the discovery to fail. |
From the NetApp Console menu, select Protection > Backup and recovery.
Under Workloads, select the KVM tile.
Select Discover resources.
Enter the following information:
Workload type: Select KVM.
If you haven't yet integrated your management platform with Backup and Recovery, select Add management platform.
Management platform IP address or FQDN: Enter the IP address or an FQDN of the management platform.
API key: Enter the API key to use to authenticate API requests.
Secret Key: Enter the secret key to use to authenticate API requests.
Port: Enter the port to use for communication between Backup and Recovery and the management platform.
Agents: Select a Console agent to use to facilitate communication between Backup and Recovery and the management platform.
When finished, select Add.
KVM settings: Do the following:
If you haven't yet stored credentials for this KVM host, select Add credentials.
Select the Console agent to use with this host.
Enter a name for this credential.
Enter the user name and password for the account.
Select Done.
Add a new KVM host by entering the following information:
KVM FQDN or IP address: Enter the host's FQDN or IP address.
Agents: Choose the Console agent to use for communication between Backup and Recovery and the KVM host.
Credentials: Select a stored credential for the KVM host.
Advanced settings: Optionally, enter a port to communicate with the KVM host and select the host's management platform from the list.
Select Discover.
This process might take a few minutes.
The KVM workload is displayed in the list of workloads on the Inventory page.
Continue to the NetApp Backup and Recovery Dashboard
Select the KVM workload tile.
From the Backup and Recovery menu, select Dashboard.
Review the health of data protection. The number of at risk or protected workloads increases based on the newly discovered, protected, and backed up workloads.
