Advanced restore settings for Kubernetes in NetApp Backup and Recovery
Use annotations, namespace settings, and storage options to customize Kubernetes restore operations for your environment.
Namespace annotations and labels during restore and failover operations
During restore and failover, destination namespace labels and annotations are updated to match the source: keys from the source are added to or overwrite destination keys, while keys that exist only in the destination are left unchanged.
In Red Hat OpenShift, namespace annotations are important because they ensure restored pods receive the correct security context constraints and permissions, enabling them to access volumes and run without permission errors. For more information, refer to the OpenShift security context constraints documentation. |
Set the Kubernetes environment variable
RESTORE_SKIP_NAMESPACE_ANNOTATIONS
before restore or failover to prevent specific destination namespace annotations from being overwritten. For example:
helm upgrade trident-protect -n trident-protect netapp-trident-protect/trident-protect \
--set-string restoreSkipNamespaceAnnotations="{<annotation_key_to_skip_1>,<annotation_key_to_skip_2>}" \
--reuse-values
During restore or failover, any namespace annotations and labels specified in restoreSkipNamespaceAnnotations and restoreSkipNamespaceLabels are excluded from the restore or failover operation. Configure these settings during the initial Helm installation. To learn more, refer to Configure additional Trident Protect helm chart settings.
If you used Helm with the --create-namespace flag to install the source application, Trident Protect copies the name label to the destination namespace. If the label value matches the source namespace name, it is replaced with the destination namespace name; if not, it is left as-is.
Example
The following example shows source and destination namespaces with different labels and annotations, and displays the destination namespace before and after the operation to illustrate how keys are added, merged, or overwritten.
Before the restore or failover operation
The following table illustrates the state of the example source and destination namespaces before the restore or failover operation:
| Namespace | Annotations | Labels |
Namespace ns-1 (source) |
Namespace ns-2 (destination) |
After the restore operation
The following table illustrates the state of the example destination namespace after the restore or failover operation. The operation added some keys, overwrote others, and updated the name label to match the destination namespace:
Supported fields
Restore operations support these additional fields.
Storage class mapping
The spec.storageClassMapping attribute maps a storage class in the source application to a new storage class on the target cluster. Use this field when migrating applications between clusters with different storage classes or when changing the storage backend for BackupRestore operations.
Example:
storageClassMapping:
- destination: "destinationStorageClass1"
source: "sourceStorageClass1"
- destination: "destinationStorageClass2"
source: "sourceStorageClass2"
Supported annotations
Use these annotations to configure system behavior. If you don't set an annotation, the system uses the default value.
| Annotation | Type | Description | Default value |
protect.trident.netapp.io/data-mover-timeout-sec |
string |
The maximum time, in seconds, that a data mover operation can remain stalled. |
"300" |
protect.trident.netapp.io/kopia-content-cache-size-limit-mb |
string |
The maximum size limit (in megabytes) for the Kopia content cache. |
"1000" |
protect.trident.netapp.io/pvc-bind-timeout-sec |
string |
Maximum time (in seconds) to wait for any newly created PersistentVolumeClaims (PVCs) to reach the |
"1200" (20 minutes) |
