NetApp Backup and Recovery
Create and manage protection groups for Oracle Database workloads with NetApp Backup and Recovery
Contributors netapp-mwallis
Create protection groups to manage backup operations for Oracle Database resources. A protection group is a logical grouping of resources, such as databases, that you want to protect together.
You can perform the following tasks related to protection groups:
Create a protection group
Group Oracle Database resources that you want to protect together into a protection group.
Required NetApp Console role
Backup and Recovery super admin or Backup and Recovery backup admin role. Learn about NetApp Console access roles for all services.
Steps
  1. From the NetApp Backup and Recovery menu, select Inventory.
  2. Select a workload to view the protection details.
  3. Select the Actions icon Actions option > View details.
  4. Select the Protection groups tab.
  5. Select Create protection group.
  6. Provide a name for the protection group.
  7. Select the databases that you want to include in the protection group.
    Standby databases aren't listed by default. To list them, select Show Data Guard standby databases. If you select a database that is part of an Oracle Data Guard configuration, NetApp Backup and Recovery also adds the other database in the same configuration. It does this only if that database is discovered, can be protected, and isn't in another protection group.
  8. Select Next.
  9. Select the Backup policy to apply to the protection group. If the group includes Oracle Data Guard databases, use Data Guard settings in the policy to choose which databases are backed up. See Create and manage Oracle Database backup policies.
    If you want to create a policy, select Create new policy and follow the prompts to create a policy. See Create policies for more information.
  10. Select Next.
  11. Review the configuration.
  12. Select Create to create the protection group.
Note If you add the standby host after you create the protection group, edit the protection group and save it. NetApp Backup and Recovery adds the standby automatically. From the standby host, add only standby databases to the group. Another database from that host that needs a different backup type causes the backup to fail for that host.
Delete a protection group
Deleting a protection group removes it and all associated backup schedules. You might want to delete a protection group if it is no longer needed.
Steps
  5. Select the protection group that you want to delete.
  6. Select the Actions icon Actions option > Remove protection.
  7. Review the confirmation message about deleting the associated backups and confirm the deletion.
