NetApp Backup and Recovery
Enable preview and hidden features for NetApp Backup and Recovery
Contributors netapp-mwallis
Enable preview and hidden features in NetApp Backup and Recovery, including features that aren't yet generally available. Use preview features with caution in production environments.
Required NetApp Console role
Backup and Recovery super admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
Available preview features
You can enable the following preview features for NetApp Backup and Recovery.
Available preview feature flags
Feature flag Feature description
"folder-restore-from-local": true
Enables folder-level restore from local ONTAP volume snapshots. By default, ONTAP only supports restoring folders from object storage backups. With this flag enabled, you can also restore entire directories from local and replicated snapshots.
"prioritize-restore": true
Makes the Prioritize restore over existing job queue option selectable during the restore workflow in the Backup and Recovery web UI. When you select this option during the restore workflow, restore operations are prioritized over other queued jobs so they run even when the queue is busy.
"data-transfer-report": true
Enables the daily backup data transfer report under the Reports tab in NetApp Backup and Recovery for Volumes. The report provides daily backup and replication data transfer activity information across your environment.
"use-azure-msi-cvo": true
Enables the option to use Microsoft Entra ID managed identity authentication for Azure object storage instead of using a storage account access key. Supported for Cloud Volumes ONTAP in Azure systems running ONTAP 9.16.1 or newer (the Console agent must also reside in Azure). For more information, refer to Requirements for using Microsoft Entra ID authentication with Azure object stores.
Enable preview features
Enable preview feature flags to use functionality that is not yet generally available. Use preview features with caution in production environments.
Note These examples assume you use Docker; if you use Podman, run the equivalent Podman commands.
Steps
  1. Use SSH to log in to the Console agent.
  2. Change to the root user:
    sudo su
  3. Find the Backup and Recovery volume in Docker:
    docker volume ls | grep cbs
    The output should be similar to the following:
    local service-manager-2_cloudmanager_cbs_volume
  4. Find the mount point for the volume:
    docker volume inspect service-manager-2_cloudmanager_cbs_volume | grep Mountpoint
    The mount point differs between cloud and private deployments. This output example shows a cloud deployment:
    /var/lib/docker/volumes/service-manager-2_cloudmanager_cbs_volume/_data
  5. Change to the docker volume config directory, which is inside the mountpoint directory. For example:
    cd /var/lib/docker/volumes/service-manager-2_cloudmanager_cbs_volume/_data/cbs_config
  6. Create a file that contains the following JSON structure and a key/value pair for each feature flag you want to enable. Name the file based on your deployment type:
    • Cloud deployment: production-customer.json
    • Private / dark site deployment: darksite-customer.json
      Refer to available flags for feature flag information. As an example:
        "feature-flags": {
          "folder-restore-from-local": true,
  7. Restart the Backup and Recovery container:
    docker restart cloudmanager_cbs
  8. Reload the Backup and Recovery UI in your web browser.
    Note To disable a preview feature, follow the same steps but set the feature flag value to false.
Disable indexing for volumes
Disable indexing for specific volumes or for all volumes belonging to one or more storage VMs by using the following option flags:
  • svms-not-to-index: A comma-separated list of storage VMs whose volumes should not be indexed
  • volumes-not-to-index: A comma-separated list of individual volume IDs of volumes that should not be indexed
Steps
    sudo su
    cd /var/lib/docker/volumes/service-manager-2_cloudmanager_cbs_volume/_data/cbs_catalog_config
  6. Create a file named production-customer.json and customize the storage VM names and volume IDs to match your environment:
      "indexing": {
        "svms-not-to-index": "storage_vm_name_1,storage_vm_name_2,storage_vm_name_3",
        "volumes-not-to-index": "volume_ID_1,volume_ID_2,volume_ID_3"
  7. Restart the Backup and Recovery indexing catalog container:
    docker restart cloudmanager_cbs_catalog
