NetApp Backup and Recovery
Supported Google archive storage tiers with NetApp Backup and Recovery
Contributors netapp-mwallis
NetApp Backup and Recovery supports the Google Cloud Storage Archive tier for older backups. Learn about the restore costs and retrieval times for backups in this tier.
Supported Google archival storage classes for NetApp Backup and Recovery
When backup files are initially created, they're stored in Standard storage. This tier is optimized for storing data that's infrequently accessed, but it still allows immediate access.
If your on-premises cluster uses ONTAP 9.12.1 or later, you can tier older backups to Archive storage in the NetApp Backup and Recovery UI after a certain number of days (typically more than 30 days) for further cost optimization. Data in this tier has a higher retrieval cost, so consider how often you might need to restore data from these archived backup files. See the section on this page about restoring data from archival storage.
When you configure NetApp Backup and Recovery with this type of lifecycle rule, don't configure any lifecycle rules when you set up the bucket in your Google account.
Restore data from archival storage
Storing older backup files in Archive storage is much less expensive than Standard storage. However, restoring data from a backup file in Archive storage takes slightly longer and costs more.
How much does it cost to restore data from Google Archive?
For detailed Google Cloud Storage pricing by region, visit the Google Cloud Storage pricing page.
How long will it take to restore my objects archived in Google Archive?
The total restore time has two parts:
  • Retrieval time: The time to retrieve the backup file from Archive and place it in Standard storage. This is sometimes called the "rehydration" time. Unlike the "coldest" storage solutions provided by other cloud providers, your data is accessible within milliseconds.
  • Restore time: The time to restore the data from the backup file in Standard storage. This time is the same as a typical restore directly from Standard storage when you don't use an archival tier.
Note
Restoring a volume or file from archive storage can take additional time. The job remains In progress in the Job Monitor while Backup and Recovery retries the restore based on the selected priority.
Monitor the restore in the Job Monitor; it completes when the job reaches a final status, such as Completed or Failed, after all retry attempts. Don't start another restore unless the job ultimately fails.
