NetApp Backup and Recovery
Policy differences between SnapCenter and NetApp Backup and Recovery
Contributors netapp-mwallis
SnapCenter and NetApp Backup and Recovery handle policy schedules, retention, and labels differently, which can affect imported resources and policies.
Schedule tiers
SnapCenter uses the following schedule tiers:
  • Hourly: Multiple hours and minutes with any hours (0-23) and any minutes (0-60).
  • Daily: Option to repeat every set number of days, for example, every 3 days.
  • Weekly: Sunday to Monday, with an option to perform a snapshot on Day 1 of the week or on multiple days of the week.
  • Monthly: January to December, with an option to perform on specific or multiple days each month, for example, the 7th.
NetApp Backup and Recovery uses the following schedule tiers, which differ slightly:
  • Hourly: Performs snapshots only on 15-minute intervals, for example, 1 hour or 15-minute intervals less than 60.
  • Daily: Hours of the day (0-23) with start time for example at 10:00 AM with an option to perform every so many hours.
  • Weekly: Day of the week (Sunday to Monday) with an option to perform on 1 day or multiple days. This is the same as SnapCenter.
  • Monthly: Dates of the month (0-30) with a starting time on multiple dates of the month.
  • Yearly: Monthly. This matches SnapCenter's monthly.
Multiple policies in SnapCenter with the same schedule tier
You can assign multiple policies with the same schedule tier to a resource in SnapCenter. However, NetApp Backup and Recovery does not support multiple policies on a resource that uses the same schedule tier.
Example: If you use three policies (for Data, Log, and Log of snapshots) in SnapCenter, after migration from SnapCenter, NetApp Backup and Recovery uses a single policy instead of all three.
Imported SnapCenter daily schedules
NetApp Backup and Recovery adjusts SnapCenter schedules as follows:
  • If the SnapCenter schedule is set to less than or equal to 7 days, NetApp Backup and Recovery sets the schedule to weekly. Some snapshots are skipped during the week.
    Example: If you have a SnapCenter daily policy with a repeating interval of every 3 days starting on Monday, NetApp Backup and Recovery sets the schedule to weekly on Monday, Thursday, and Sunday. Some days will be skipped because it is not exactly every 3 days.
  • If the SnapCenter schedule is set to greater than 7 days, NetApp Backup and Recovery sets the schedule to monthly. Some snapshots will be skipped during the month.
    Example: If you have a SnapCenter daily policy with a repeating interval of every 10 days starting on the 2nd of the month, NetApp Backup and Recovery, after migration, sets the schedule to monthly on the 2nd, 12th, and 22nd day of the month. NetApp Backup and Recovery skips some days in the next month.
Imported SnapCenter hourly schedules
SnapCenter hourly policies with repeating intervals greater than one hour are converted to a daily policy in NetApp Backup and Recovery.
Any hourly policy with a repeating interval that is not a factor of 24, for example 5 or 7, skips some snapshots in a day.
Example: If you have a SnapCenter hourly policy with a repeating interval every 5 hours starting at 1:00 AM, NetApp Backup and Recovery (after migration) will set the schedule to daily with 5-hour intervals at 1:00 AM, 6:00 AM, 11:00 AM, 4:00 PM, and 9:00 PM. Some hours are skipped. After 9:00 PM, the next snapshot should be at 2:00 AM to repeat every 5 hours, but it is always at 1:00 AM.
Log retention from SnapCenter policies
If you have a resource in SnapCenter with multiple policies, NetApp Backup and Recovery uses the following priority order to assign the log retention value:
  • For "Full backup with log backup policy" plus "log-only" policies in SnapCenter, NetApp Backup and Recovery uses the log-only policy retention value.
  • For "Full backup with log only" and "Full and Log" policies in SnapCenter, NetApp Backup and Recovery uses the log-only retention value.
  • For "Full backup and log" plus "Full backup" in SnapCenter, NetApp Backup and Recovery uses the "Full backup and log" retention value.
  • If you have only a full backup in SnapCenter, NetApp Backup and Recovery does not enable the log backup.
Log backup retention
SnapCenter supports multiple retention values for policies on a resource. NetApp Backup and Recovery supports only one retention value per resource.
Retention count from SnapCenter policies
If you have a resource with secondary protection enabled in SnapCenter with multiple source volumes, multiple destination volumes, and multiple SnapMirror relationships, NetApp Backup and Recovery uses only the first policy's retention count.
Example: If you have a SnapCenter policy with a retention count of 5 and another policy with a retention count of 10, NetApp Backup and Recovery uses the retention count of 5.
SnapMirror labels from SnapCenter policies
SnapCenter keeps SnapMirror labels for each policy after migration, even if the tier changes.
Example: An hourly policy from SnapCenter might change to daily in NetApp Backup and Recovery. However, the SnapMirror labels remain the same after migration.
