NetApp Backup and Recovery
Restart NetApp Backup and Recovery
Contributors netapp-mwallis
You can restart NetApp Backup and Recovery from the Console agent host when you need to recover the service or apply a change. Use the command that matches your deployment type and container runtime.
The Console agent includes NetApp Backup and Recovery functionality.
Steps
  1. Connect to the Linux system where the Console agent is running.
    Console agent location Procedure
    Cloud deployment
    Follow the instructions for connecting to the Console agent Linux virtual machine depending on the cloud provider you're using.
    Manual installation
    Log in to the Linux system.
  2. Enter the command to restart the service.
    Console agent location Docker command Podman command
    Cloud deployment
    docker restart cloudmanager_cbs
    podman restart cloudmanager_cbs
    Manual installation with internet access
    Manual installation without internet access
    docker restart ds_cloudmanager_cbs_1
    podman restart ds_cloudmanager_cbs_1
