Supported sync relationships in NetApp Copy and Sync
NetApp Copy and Sync enables you to sync data from a source to a target. This is called a sync relationship. You should understand the supported relationships before you get started.
| Source location | Supported target locations |
Amazon EFS |
Amazon FSx for ONTAP |
Amazon S3 |
Azure Blob |
Azure Data Lake Storage Gen2 |
Azure NetApp Files |
Box 1 |
Cloud Volumes ONTAP |
Google Cloud Storage |
Google Drive |
IBM Cloud Object Storage |
NFS server |
On-premises ONTAP cluster (NFS or SMB) |
ONTAP S3 Storage |
SFTP 2 |
S3 |
SMB server |
StorageGRID |
Notes:
Box support is available as a preview.
Sync relationships with this source/target are supported by using the Copy and Sync API only.
You can choose a specific Azure Blob storage tier when a Blob container is the target:
Hot storage
Cool storage
You can choose a specific S3 storage class when Amazon S3 is the target:
Standard (this is the default class)
Intelligent-Tiering
Standard-Infrequent Access
One Zone-Infrequent Access
Glacier Deep Archive
Glacier Flexible Retrieval
Glacier Instant Retrieval
You can choose a specific storage class when a Google Cloud Storage bucket is the target:
Standard
Nearline
Coldline
Archive
