NetApp Copy and Sync
Page title goes here
Use this template for articles, topics, whatever you call them. The index.adoc file does not have the correct keywords for an article page and using it as a template can cause publishing problems later on.
Note Delete this file before initial publishing, as the file will be published even if it's not linked to the sidebar. After you create a few articles you can use them as a starter instead.
If your articles will be in a content sub-folder, you will need to make two adjustments to the notation shown above:
  • :imagesdir:../media/
  • permalink: folder-name/sample-article.html
