NetApp Data Classification
Supported NetApp Data Classification instance types
Contributors netapp-ahibbard
NetApp Data Classification software must run on a host that meets specific operating system requirements, RAM requirements, and software requirements. When deploying Data Classification in the cloud, use a system with the "large" characteristics for full functionality.
In the following tables, if the system marked "default" isn't available in the region where you are installing Data Classification, the next instance type listed in the table will be deployed.
AWS instance types
System size Specs Instance type
Extra Large
32 CPUs, 128 GB RAM, 1 TiB gp3 SSD
m6i.8xlarge (default)
Large
16 CPUs, 64 GB RAM, 500 GiB SSD
m6i.4xlarge (default)
m6a.4xlarge
m5a.4xlarge
m5.4xlarge
m4.4xlarge
Azure instance types
Extra Large
16 CPUs, 64 GB RAM, OS Disk (2,048 GiB, min 250 MB/s throughput), and Data Disk (1 TiB SSD, min 750 MB/s throughput)
Standard_D32s_v5 or Standard_D32_v5
Large
Standard_D16_v5 or Standard_D16s_v5 (default)
GCP instance types
Large
n2-standard-16 (default)
n2d-standard-16
n1-standard-16
