NetApp Data Classification
Copy, move, and delete files using NetApp Data Classification
Contributors netapp-ahibbard
NetApp Data Classification enables you to perform actions on files discovered in the Investigation dashboard. After filtering data, you can copy, move, and delete unstructured data to improve compliance—for example, by moving sensitive files to a more secure location—or to create savings by deleting old or duplicate files.
Copy files
Data Classification supports copying files that are up to 1 GB in size. You can copy a total of 1 TB of data or 5 million files, whichever limit is reached first. You can copy files to a CIFS or NFS destination. There's no impact on the source file when you copy it.
Steps
  1. In the Investigation dashboard, select the files you want to copy.
  2. Above the list of files, select Copy.
    Screenshot of actions in the Investigation page
  3. Select the protocol of the destination for the copies: NFS or CIFS.
  4. If you selected NFS, enter the destination path using forward slashes, for example hostname:/path/to/destination.
    If you selected CIFS, enter the destination path using backslashes, for example \\server\share\path. Also enter the Username and Password credentials for the CIFS share.
    Screenshot of the copy function for NFS files
  5. Select Submit.
Move files
Data Classification supports moving files that are up to 1 GB in size. You can move a total of 1 TB of data or 5 million files, whichever limit is reached first. You can move files to a CIFS or NFS destination.
Steps
  1. In the Investigation dashboard, select the files you want to move.
  2. Above the list of files, select Move.
  3. Select the destination's protocol: NFS or CIFS.
  5. Optionally, select Leave breadcrumb to leave a breadcrumb file in the source volume that explains where and why the file was moved.
    1. If you selected Leave breadcrumb, enter a descriptive text that notes the rationale for moving the file and, if necessary, the new location.
      Screenshot of the move function for NFS files
  6. Select Move items.
Delete files
When you filter data on the Investigation dashboard to discover space and cost saving opportunities, you can delete those files. You can delete only unstructured files.
Steps
  1. In the Investigation dashboard, select the files you want to delete.
  2. In the confirmation dialog, enter "permanently delete".
  3. Select Delete File to confirm the operation.
    Screenshot of the delete dialog
