NetApp Data Classification
Uninstall NetApp Data Classification
Contributors netapp-ahibbard
You can uninstall NetApp Data Classification to troubleshoot issues or to permanently remove the software from the host. Deleting the instance also deletes the associated disks where the indexed data resides, meaning all the information Data Classification has scanned will be permanently deleted.
The steps that you need to use depend on whether you deployed Data Classification in the cloud or on an on-premises host.
Uninstall Data Classification from a cloud provider
  1. From Data Classification, select Configuration.
  2. Switch to the Settings tab.
  3. Select Uninstall Data Classification.
  4. In the dialog, enter "uninstall" to proceed with disconnecting the Data Clasification instance from the Console agent. Select Uninstall to confirm.
  5. In the Uninstall Classification dialog, type uninstall to confirm that you want to disconnect the Data Classification instance from the Console agent then select Uninstall.
  6. To finalize the uninstall process, go to your cloud provider's console and delete the Data Classification instance. The instance is named CloudCompliance with a generated hash (UUID) concatenated to it. For example: CloudCompliance-16bb6564-38ad-4080-9a92-36f5fd2f71c7
Uninstall Data Classification from an on-premises deployment
    A screenshot of the button to uninstall Data Classification.
  4. In the dialog, enter "uninstall" to proceed with disconnecting the Data Classification instance from the Console agent. Select Uninstall to confirm.
  5. To uninstall the software from the host, run the cleanup.sh script on the Data Classification host machine, for example:
    cleanup.sh
    The script is located in the /install/light_probe/onprem_installer/cleanup.sh directory.
    See how to log in to the Data Classification host machine.
