Create a replication plan: Step 4 - Verify settings in NetApp Disaster Recovery
After you add the replication plan information in NetApp Disaster Recovery, verify that the information you entered is correct.
Steps
Select Save to review your settings before activating the replication plan.
You can select each tab to review the settings and make changes on any tab by selecting the pencil icon.
Replication plan settings review
When you are satisfied that all settings are correct, select Add plan at the bottom of the screen.
Continue with Verify the replication plan.
