NetApp Disaster Recovery
Monitor NetApp Disaster Recovery jobs
Contributors netapp-ahibbard amgrissino
Monitor NetApp Disaster Recovery jobs to view their history, status, and details. Tracking job status and progress enables you to catch failed or stalled operations before they affect recovery readiness.
About job monitoring
If you rerun a failed, canceled, or timed-out discovery, resync, compliance, protection, replication plan, or backup retention job, Disaster Recovery registers the rerun as a new job and records the user who initiated it, so you can see who performed each action. Reruns of failback, failover, and migration operations are listed under the original job, and the user who initiated the rerun isn't listed.
View jobs
Required NetApp Console role
The Super admin, Disaster recovery admin, Disaster recovery application admin, or Disaster recovery viewer role is required to perform this task. Learn about user roles and permissions in NetApp Disaster Recovery. Learn about NetApp Console access roles for all services.
Steps
  1. Log in to the NetApp Console.
  2. From the NetApp Console left navigation, select Protection > Disaster recovery.
  3. From the menu, select Job monitoring.
  4. Review jobs, including their timestamps and status.
  5. To view details for a job, select its row. To download job details for offline review, select the action menu and then select Download job details.
    Tip When you review job details, Disaster Recovery shows the user who initiated the job. If the responsible party is listed as "system," Disaster Recovery initiated the job.
  6. To refresh information, select Refresh.
Cancel a job
You can cancel a job that's in progress or queued if it's stuck or if you need to prioritize a pending operation.
The Super admin, Disaster recovery admin, Disaster recovery failover admin, or Disaster recovery application admin role is required to perform this task. Learn about user roles and permissions in NetApp Disaster Recovery. Learn about NetApp Console access roles for all services.
Steps
  1. From the NetApp Console left navigation, select Protection > Disaster recovery.
  2. From the menu, select Job monitoring.
  3. On the Job monitoring page, note the ID of the job that you want to cancel.
    The job must be in an "In progress" or "Queued" state.
  4. Select the action menu, then select Cancel job.
