Learn about replication policies used in NetApp Replication
You might need help choosing a replication policy when you set up data replication in NetApp Replication. A replication policy defines how the storage system replicates data from a source volume to a destination volume.
What replication policies do
The ONTAP operating system automatically creates backups called snapshot copies. A snapshot copy is a read-only image of a volume that captures the state of the file system at a point in time.
When you replicate data between systems, you replicate snapshot copies from a source volume to a destination volume. A replication policy specifies which snapshot copies to replicate from the source volume to the destination volume.
Replication policies are also referred to as protection policies because they are powered by SnapMirror and SnapVault technologies, which provide disaster recovery protection and disk-to-disk backup and recovery. |
The following image shows the relationship between snapshot copies and replication policies:
Types of replication policies
There are three types of replication policies:
A Mirror policy replicates newly created snapshot copies to a destination volume.
You can use these snapshot copies to protect the source volume in preparation for disaster recovery or for one-time data replication. You can activate the destination volume for data access at any time.
A Backup policy replicates specific snapshot copies to a destination volume and typically retains them for a longer period of time than you would on the source volume.
You can restore data from these snapshot copies when data is corrupted or lost, and retain them for standards compliance and other governance-related purposes.
A Mirror and Backup policy provides both disaster recovery and long-term retention.
Each system includes a default Mirror and Backup policy, which works well for many situations. If you find that you need custom policies, you can create your own using System Manager.
The following images show the difference between the Mirror and Backup policies. A Mirror policy mirrors the snapshot copies available on the source volume.
A Backup policy typically retains snapshot copies longer than they are retained on the source volume:
