Manage data replication in NetApp Replication
After you set up data replication between two systems, you can manage the data replication schedule and relationship from NetApp Replication.
Replication relationships with FSx for ONTAP file systems as source or target are managed in NetApp Workload Factory. You can manage these relationships from the Console systems page by selecting the FSx for ONTAP file system.
Continue to step 2 to manage non-FSx for ONTAP replication relationships.
To manage replication relationships with FSx for ONTAP file systems, after you log in to the NetApp Console, go to Storage > Management > Systems. Then select the FSx for ONTAP file system. Now you're in Workload Factory in the FSx for ONTAP resource screen. Select the Replication relationships tab to view and manage the replication relationships for the file system.
Review the status of the data replication relationships to verify that they are healthy.
If the status of a relationship is idle and the Mirror State is uninitialized, you must initialize the relationship from the destination system for the data replication to occur according to the defined schedule. You can initialize the relationship by using System Manager or the command-line interface (CLI). These states can appear when the destination system fails and then comes back online. -
Select the action menu for a volume relationship and choose one of the available actions.
The following table describes the available actions:
Action Description Information
Shows you details about the volume relationship: transfer information, last transfer information, details about the volume, and information about the protection policy assigned to the relationship.
Break
Breaks the relationship between the source and destination volumes, and activates the destination volume for data access.
This option is typically used when the source volume cannot serve data due to events such as data corruption, accidental deletion, or an offline state.
Learn how to configure a destination volume for data access and reactivate a source volume in the ONTAP documentationResync
Reestablishes a broken relationship between volumes and resumes data replication according to the defined schedule.
When you resynchronize the volumes, the contents on the destination volume are overwritten by the contents on the source volume. Learn how to perform a reverse resync, which resynchronizes the data from the destination volume to the source volume, go to the ONTAP documentation.
Reverse Resync
Reverses the roles of the source and destination volumes. Contents from the original source volume are overwritten by contents of the destination volume. This is helpful when you want to reactivate a source volume that went offline.
Any data written to the original source volume between the last data replication and the time that the source volume was disabled is not preserved.Edit Schedule
Enables you to choose a different schedule for data replication.
Edit Max Transfer Rate
Enables you to edit the maximum rate (in kilobytes per second) at which data can be transferred.
Update
Starts an incremental transfer to update the destination volume.
Delete
Delete the data protection relationship between the source and destination volumes. This ends data replication between volumes, deletes the SnapMirror relationship from the destination site, and releases the relationship from the source site.
Deleting the relationship also breaks the SnapMirror relationship, which briefly makes the destination volume the primary site for read/write operations to ensure the destination can be used independently after replication is removed.
After you select an action, NetApp Replication updates the relationship or schedule.
