Workload Factory for NetApp Console
Learn about Codebox automation in NetApp Workload Factory
Contributors netapp-rlithman
Codebox is an Infrastructure as Code (IaC) co-pilot that helps developers and DevOps generate the code needed to execute any operation supported by NetApp Workload Factory. Codebox is aligned with the Workload Factory permission policies and it sets a clear path for execution readiness as well as providing an automation catalog for quick future reuse.
Codebox capabilities
Codebox provides two key IaC capabilities:
  • Codebox Viewer shows the IaC that is generated by a specific job flow operation by matching entries and selections from the graphical wizard or from the conversational chat interface. While Codebox Viewer supports color coding for easy navigation and analysis, it does not allow editing—​only copying or saving code to the Automation Catalog.
  • Codebox Automation Catalog shows all saved IaC jobs, allowing you to easily reference them for future use. Automation catalog jobs are saved as templates and shown in context of the resources that apply to them.
Additionally, when setting up Workload Factory credentials, Codebox dynamically displays the AWS permissions that are needed to create IAM policies. The permissions are provided for each Workload Factory capability that you plan to use (databases, AI, FSx for ONTAP, and so on), and they are customizable. You just copy the permissions from Codebox and then paste them in the AWS Management Console so that Workload Factory has the correct permissions to manage your workloads.
Supported code formats
The supported code formats include:
  • Workload Factory REST APIs
  • AWS CLI
  • AWS CloudFormation
  • Terraform
