Workload Factory for NetApp Console
Manage block storage for a file system in NetApp Workload Factory
Contributors netapp-rlithman
Use NetApp Workload Factory to simplify managing your block storage resources, including igroups and block devices, and control client access for FSx for ONTAP block devices to provide optimal performance and minimize costs. Refer to the block device igroup diagram to optimize client connections and resolve issues quickly.
About this task
From the Workload Factory console, you can manage initiator groups (igroups) to control client access to block devices. You can also view block device details, increase capacity, make clones, manage client access, archive data for inactive block devices, and delete block devices.
Use the block storage diagram to check for the following:
  • Host details including host name, instance ID, workload type, region, and iSCSI Qualified Name (IQN)
  • Client connections
  • Block device status
  • Node-client relationship
  • Potentially incorrect client connections
Before you begin
Manage igroups
You can view igroup details, manage client access, and delete igroups.
Manage client access for an igroup
Manage client access for an existing igroup at any time.
Steps
  1. Log in to the NetApp Console.
  2. Select the menu The hamburger menu icon is used to navigate to Workloads, Workloads > Storage > FSx for ONTAP.
  3. From FSx for ONTAP, select the Block devices tab.
  4. Select the resource type Initiator groups (igroups) to view existing igroups.
  5. Go to the actions menu for the block device and select Manage client access.
  6. Review the client access details displayed for the igroup.
  7. To make changes to client access, select Edit client access.
  8. In the Edit client access dialog, you can edit the following:
    • igroup name
    • igroup description
    • Storage VM name
    • Block device name
    • Operating system type
    • Host initiators
  9. Select Apply.
Delete an igroup
Delete an igroup when it is no longer needed.
Steps
  5. Go to the actions menu for the block device and then select Delete initiator group.
  6. In the Delete initiator group (igroup) dialog, type "delete" to confirm that you want to delete the igroup, and then select Delete.
Manage block devices for an igroup
Block devices, or LUNs (logical unit numbers), are volumes with file systems in a SAN environment, accessible to hosts over a network.
You can manage block devices for FSx for ONTAP file systems that use the iSCSI protocol.
View block device details
View details for an existing block device at any time.
Steps
  4. Navigate to the actions menu for the block device and then select View details.
    Workload Factory displays general details, consumption, access, and protection information for the block device.
Manage client access for a block device
You can manage client access for an existing block device at any time by creating igroups, and adding or removing block devices and host initiators.
Steps
  4. Navigate to the actions menu for the block device and then select Manage client access.
  5. If no igroup exists, create a new igroup by selecting Map igroup > Create igroup, and then do the following:
    1. Block device name: Enter a block device name. You can select multiple block devices to associate with the igroup.
    2. Operating system type: Select the operating system type.
    3. igroup name: Enter an igroup name.
    4. igroup description: Optionally, enter an igroup description.
    5. Host initiators: Enter one or more host initiators. These initiators must follow iSCSI qualified (IQN) format.
    6. Select Create.
  6. If an igroup already exists, select Map igroup > Map existing igroup to add or remove block devices and host initiators from the igroup and then select Map.
Increase the capacity of a block device
Increase the capacity of an existing block device at any time.
Steps
  4. Navigate to the actions menu for the block device and then select Increase capacity.
  5. Enter the new capacity for the block device and select the unit.
  6. Select Increase to apply the changes.
Note After increasing the size of the block device, follow the procedure your host operating system provides to discover the new size and expand the file system.
Clone a block device
You can create a clone of an existing block device at any time. A block device clone is a writable copy of the original block device that shares the same data blocks until changes are made to either the original or the clone. Cloning a block device is a quick and efficient way to create reusable copies of your data without consuming additional storage capacity.
Steps
  4. Navigate to the actions menu for the block device and then select Clone block device.
  5. In the Clone block device dialog, enter a name for the cloned block device.
  6. Optionally, enable autodelete to automatically delete the cloned block device when the volume is low on space.
  7. iSCSI configuration: Optional. To connect the block device clone to host initiators, either create a new initiator group or map it to an existing initiator group.
    • Create a new initiator group: Select this option to create a new initiator group for the block device clone. Enter the following details:
      1. Host operating system: Select the host operating system type.
      2. Initiator group name: Enter an igroup name.
      3. Host initiators: Enter one or more host initiators. These initiators must follow iSCSI qualified (IQN) format.
    • Map to an existing initiator group: Select this option to map the block device clone to an existing initiator group. Select one or more initiator groups to map the block device to.
  8. Select Clone to create the block device clone.
Archive the data of an inactive block device
Block devices that are no longer mapped to a client or unused for seven consecutive days are classified as inactive block devices. You can archive the data of an inactive block device to the capacity pool tier to reclaim SSD capacity.
Note A volume with child clones cannot be deleted until all child clones are either deleted or separated into independent volumes.
Before you begin
Make sure all block devices (LUNs) are inactive on the same volume before you archive the data.
Steps
  4. Under Orphan devices, select View and reclaim capacity.
  5. On the Reclaim space for unused block devices screen, select one or more block devices to archive the data and reclaim the capacity.
  6. Select Archive.
Delete a block device
Block devices that are not mapped to a client or are unused for seven days are inactive block devices. This operation unmaps and deletes the selected block device. If the host FlexVol volume does not contain any block devices, Workload Factory deletes it.
Steps
  5. On the Reclaim space for unused block devices screen, select one or more block devices to reclaim the capacity.
  6. Select Delete.
