Manage volume capacity in NetApp Workload Factory
Adjust volume capacity as your needs change. Increase or decrease volume size manually, turn on volume autogrow to let Workload Factory manage capacity for you, or rebalance FlexVol and FlexGroup volume capacity to spread files evenly across all FlexVol volumes in a node or across all constituents so that all nodes participate in the workload of a single FlexGroup volume.
Edit volume autogrow
Turn on volume autogrow to let Workload Factory manage volume capacity for you. You can disable it at any time.
Volume autogrow isn't supported for iSCSI volumes. |
To enable volume autogrow, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Log in to the NetApp Console.
Select the menu
, Workloads > Volumes explorer. -
Select the actions menu for the volume you want to modify.
Select Basic actions, then Set volume autogrow.
In the Set autogrow dialog, enable volume autogrow to automatically expand the volume capacity until the volume reaches the maximum size. This feature accommodates increasing data usage, ensuring uninterrupted operations.
Specify the maximum volume growth size and unit. The maximum growth size cannot be smaller than the current volume size.
Select Apply.
Adjust volume capacity manually
You can adjust volume capacity by increasing or decreasing the provisioned size of a volume. Minimum and maximum sizes vary by volume type:
| Volume type | Minimum size | Maximum size |
FlexVol volume |
20 MiB |
300 TiB |
FlexGroup volume |
800 GiB |
2 PiB |
For an iSCSI LUN, increasing the size of the volume also increases the size of the host LUN. After you increase volume capacity, follow the procedure provided by your host operating system to discover the new size of the LUN and expand the file system of the LUN.
Decreasing volume size is supported only for NFS and SMB/CIFS volumes.
To adjust volume capacity, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Select the menu
Select Basic actions, then Adjust volume capacity.
In the Adjust volume capacity dialog, set the Provisioned capacity and unit.
Select Adjust to apply the changes.
Rebalance volume capacity for FlexVol and FlexGroup volumes
Rebalancing volume capacity is supported for FlexVol volumes and FlexGroup volumes. Rebalancing a volume redistributes the capacity when imbalances develop over time due to the addition of new files and file growth. After you manually start the rebalance operation, Workload Factory selects the files and moves them automatically and non-disruptively. Volume transfer operations consume file system resources.
Rebalancing differs by volume type.
FlexVol volumes are logical containers that offer flexibility in managing data, allowing for expansion, contraction, movement, and efficient copying. They can be used with NAS and SAN environments.
A FlexVol volume can be balanced in relation to other FlexVol volumes within one node in an FSx for ONTAP file system. If the file system has only a single FlexVol volume, then rebalancing isn't possible. When the file system has more than one FlexVol volume per node and a single FlexVol volume is selected, the FlexVol volume is balanced in the context of all FlexVols but only the selected volume is allowed to move.
FlexGroup volumes, on the other hand, are scalable NAS containers designed for high performance and automatic load distribution. They consist of multiple member volumes (constituents) that share traffic transparently. FlexGroup volumes provide massive capacity, exceeding FlexVol limits, with up to 60PB capacity and 400 billion files. They simplify management by offering a single namespace container.
Capacity is spread across a number of constituents in a scale-out FSx for ONTAP file system with two or more high availability (HA) pairs. Each constituent is a container that dictates the maximum single file size. FSx for ONTAP spreads files across all constituents evenly so all nodes participate in the workload of a single FlexGroup volume.
When the constituents aren't distributed evenly across all nodes, FlexGroup volume performance decreases.
Checking the balance of FlexGroup volume capacity includes assessing the current layout of constituents. When you rebalance the volume's capacity, NetApp Workload Factory designs a new constituent layout with an even number of constituents to spread the data evenly across all HA pairs. The service executes the rebalance plan, which in turn improves read and write operations.
Rebalancing isn't supported for SAN volumes like iSCSI and NVMe. |
Check the balance of your volumes
Check the balance of FlexVol or FlexGroup volumes in an FSx for ONTAP file system.
FlexGroup volume balance is available only for FSx for ONTAP file systems using a scale-out deployment with at least two HA pairs.
To check the balance of a volume, you must create and associate a link or associate an existing link to the file system. After the link associates, return to this operation.
Select the menu
, Workloads > Storage > FSx for ONTAP. -
From FSx for ONTAP, select the actions menu of the file system that contains volumes to rebalance and then select Manage.
From the file system overview, select the Volumes tab.
From the Volumes tab, select Check volume balance at the top of the table.
In the Volume balance window, review the balance status of:
FlexGroup volumes
FlexVol volumes
When a volume is unbalanced, consider rebalancing it.
Rebalance one or more unbalanced volumes.
A Workload Factory admin can stop rebalancing during the operation. |
Check the balance of a volume before rebalancing volumes.
To rebalance a volume, you must create and associate a link or associate an existing link to the file system. After the link associates, return to this operation.
Existing snapshots on volumes you rebalance become partial and cannot be used to restore volume data, but new snapshots taken after rebalancing can be used to restore volume data.
FlexVol volumes are best rebalanced altogether to balance all volume resources evenly. Deselected volumes don't actively participate in the balancing procedure.
A FlexVol volume can be balanced in relation to other FlexVol volumes within one node in an FSx for ONTAP file system. When the file system has more than one FlexVol volume per node and a single FlexVol volume is selected, then the FlexVol volume is balanced in the context of all FlexVols but only the selected volume is allowed to move.
Select the menu
From FSx for ONTAP, select the actions menu of the file system that contains the volume to rebalance and then select Manage.
In the Volumes balance window, optionally select Data distribution in the FlexVol balance summary to view used capacity per aggregate.
Select Rebalance to rebalance one or more unbalanced volumes.
In the Rebalance wizard, follow the steps.
Max transfer rate: Optional. Disabled by default. Enable throttling to limit the bandwidth of a volume move on your file system and to slow outgoing volume replication traffic.
Enter the throttle value in MB/s.
Select Next.
Review the current and proposed layouts of all FlexVol volumes, and then select Next.
Carefully review what will happen and the note before beginning the rebalance operation.
Select Rebalance.
The FlexVol volume is rebalanced. When the operation completes, the file system will be throttled back to the original value.
Data redistributes across member volumes to rebalance the FlexGroup volume. Based on your chosen layout, the rebalance operation might add FlexGroup member volumes and increase the size of provisioned volumes.
Select the menu
From the Volumes tab, select Check FlexGroup balance at the top of the table.
In the FlexGroup balance window, select Rebalance to rebalance one or more unbalanced volumes.
In the Rebalance wizard, select the data distribution layout that you prefer.
Performance-optimized (recommended): increases the number of FlexGroup member volumes and the provisioned size of the volume. Follows NetApp best practice.
Restricted: supports volumes in a replication relationship. The number of FlexGroup member volumes and the size of provisioned volumes remains the same. Selected by default if all selected volumes participate in a replication relationship.
Manual: Select the desired number of FlexGroup member volumes per HA pair. Depending on your selection, the number of FlexGroup member volumes and the provisioned size of the volume might increase.
Throttling: Optional. Disabled by default. Enable throttling to limit the bandwidth of a volume move on your file system and to slow outgoing volume replication traffic.
Select a layout comparison view and then select Next.
Volume layout comparison
FSx for ONTAP layout comparison
Optionally, download a list of volume moves before rebalancing.
Select Rebalance.
FlexGroup member volumes are moved one at a time during rebalancing. When the operation completes, the file system will be throttled back to the original value.
Stop a volume rebalance operation
Stop a rebalance operation at any time; it isn't disruptive. Stopping the operation aborts active volume moves.
You can start another rebalance operation later.
After you begin the rebalance operation, from the Volume balance page, select Stop rebalancing.
In the Stop rebalancing dialog, select Stop.
The volume rebalance operation stops and active volume moves abort.
