Workload Factory for NetApp Console
Split a cloned volume in NetApp Workload Factory
Contributors netapp-rlithman
Split a cloned FlexVol volume from its parent volume to make the clone a normal read/write FlexVol volume in NetApp Workload Factory.
Data is accessible on the clone and the parent during the split. The split process only updates metadata and requires minimal IO. No data blocks are copied.
About this task
The clone splitting operation involves the following:
  • You can't create new snapshot copies of the FlexClone volume during the split operation.
  • You can't split a FlexClone volume from its parent volume if it belongs to a data protection relationship.
  • If you take the FlexClone volume offline during the split, the split operation suspends. When you bring the FlexClone volume back online, the split operation resumes.
  • After the split, both the parent FlexVol volume and the clone require the full space allocation determined by their volume guarantees.
  • After you split a FlexClone volume from its parent, you can't rejoin them.
Before you begin
Consider the following before you split a cloned volume:
Steps
  1. Log in to the NetApp Console.
  2. Select the menu The hamburger menu icon is used to navigate to Workloads, Workloads > Volumes explorer.
  3. Select the actions menu of the volume with the cloned volume to split.
  4. Select Data protection actions, then Split cloned volume.
  5. In the Split volume dialog, select Delete.
Result
The volume clone is split and appears in the Volumes tab.
