Known limitations with NetApp Backup and Recovery for SQL Server workloads
Contributors guillermotome
Review these limitations before using NetApp Backup and Recovery for SQL Server workloads.
Backup and Recovery preview for NetApp Console local deployment limitation
In the Backup and Recovery preview release for NetApp Console local deployment, backups to object storage are supported only for ONTAP S3 and StorageGRID destinations. Backup archiving is not supported in this preview release. this is a new sentence
Clone lifecycle support
  • Cloning from object storage is not supported.
  • Bulk clone operations are not supported for on-demand clones.
  • Choosing I-groups is not supported.
  • Choosing QOS (maximum throughput) options is not supported.
Standard deployment mode only
This NetApp Backup and Recovery version works only in standard deployment mode, not restricted or private modes.
Windows cluster name restriction
The Windows cluster name cannot contain an underscore (_) character.
SnapCenter migration issues
The migration of resources from SnapCenter into NetApp Backup and Recovery has the following limitations.
For details about how SnapCenter policies migrate to NetApp Backup and Recovery policies, see Policies in SnapCenter compared to those in NetApp Backup and Recovery.
Resource group limitations
If all the resources in a resource group are protected and one of those resources is also protected outside of the resource group, the migration from SnapCenter is blocked.
Workaround: Protect the resource either in a resource group or by itself, but not in both.
Resources with multiple policies using the same schedule tier not supported
You cannot assign multiple policies that use the same schedule tier (for example, hourly, daily, or weekly) to a resource. NetApp Backup and Recovery will not import those resources from SnapCenter.
Workaround: Attach only one policy using the same schedule tier to a resource.
Hourly policies must begin at the start of the hour
If you have a SnapCenter policy that repeats hourly but does not use intervals at the start of the hour, NetApp Backup and Recovery will not import the resource. For example, policies with schedules of 1:30, 2:30, 3:30, etc. are not supported, while policies with schedules of 1:00, 2:00, 3:00, etc. are supported.
Workaround: Use a policy that repeats in 1-hour intervals starting at the top of the hour.
Both daily and monthly policies attached to one resource not supported
If a SnapCenter policy repeats in both day and month intervals, NetApp Backup and Recovery will not import the policy.
For example, you cannot attach a daily policy (with an interval of 7 days or less, or more than 7 days) to a resource and also attach a monthly policy to the same resource.
Workaround: Use a policy that uses a daily or a monthly interval, but not both.
On-demand backup policies not migrated
NetApp Backup and Recovery does not import on-demand backup policies from SnapCenter.
Log-only backup policies not migrated
NetApp Backup and Recovery does not import log-only backup policies from SnapCenter. If a SnapCenter policy includes log-only backups, NetApp Backup and Recovery will not import the resource.
Workaround: Use a policy in SnapCenter that uses more than just log-only backups.
Host mapping
SnapCenter does not map storage clusters or storage VMs for resources to hosts, but NetApp Backup and Recovery does. The on-premises ONTAP cluster or storage VM will not be mapped to a host in NetApp Backup and Recovery preview versions. Additionally, NetApp Console does not support storage VMs.
Workaround: Before importing resources from SnapCenter, create a system in NetApp Backup and Recovery for all the on-premises ONTAP storage systems that are registered in on-premises SnapCenter. Then, import the resources for that cluster from SnapCenter into NetApp Backup and Recovery.
Schedules not in 15-minute intervals
If you have a SnapCenter policy schedule that starts at a certain time and repeats in intervals other than 15-minute intervals, NetApp Backup and Recovery will not import the schedule. test harmony ruleset
Workaround: Use SnapCenter to adjust the policy so that it repeats in 15-minute intervals.
