Known limitations with NetApp Backup and Recovery for ONTAP volumes
Contributors guillermotome
Review these limitations before using NetApp Backup and Recovery for ONTAP volumes.
  • NetApp Backup and Recovery can back up Cloud Volumes ONTAP to an object store in the AWS China regions (including Beijing and Ningxia); however, you might need to manually modify Identity and access policies first.
    For details about creating a Console agent in AWS, refer to Installing a Console agent in AWS.
    For additional details, refer to the blog post NetApp Backup and Recovery Feature Blog May 2023.
  • NetApp Backup and Recovery does not support Microsoft Azure China regions.
    For details about creating a Console agent in Azure, refer to Installing a Console agent in Azure.
  • NetApp Backup and Recovery does not support backups of FlexCache volumes.
Replication limitations for ONTAP volumes
  • You can select only one FlexGroup volume at a time for replication. You need to activate backups separately for each FlexGroup volume.
    FlexVol volumes have no such limitation: you can select all FlexVol volumes in your system and assign the same backup policies.
  • The following functionality is supported in NetApp Replication, but not when using the replication feature of NetApp Backup and Recovery:
    • There is no support for a cascade configuration where replication occurs from volume A to volume B and from volume B to volume C. Support includes replication from volume A to volume B.
    • There is no support for replicating data to and from FSx for ONTAP systems.
    • There is no support for creating a one-time replication of a volume.
  • When creating replications from on-premises ONTAP systems, if the ONTAP version on the target Cloud Volumes ONTAP system is 9.8, 9.9, or 9.11, only mirror-vault policies are allowed.
  • When you convert a FlexVol volume to a FlexGroup volume or vice versa, the converted volume is considered a new volume; you need to set up protection for the converted volume after conversion. You can restore backups created before the conversion to a different volume.
Backup-to-object limitations for ONTAP volumes
  • In the Backup and Recovery preview release for NetApp Console local deployment, backups to object storage are supported only for ONTAP S3 and StorageGRID destinations. Backup archiving is not supported in this preview release.
  • When backing up data, NetApp Backup and Recovery will not maintain NetApp Volume Encryption (NVE). This means that encrypted data on the NVE volume will be decrypted while the data is being transferred to the destination and the encryption will not be maintained.
    For an explanation about these encryption types, refer to
    Configure NetApp Volume Encryption overview.
  • Do not back up SnapMirror destination volumes that have long-term retention snapshots enabled. These snapshots are created directly on the destination and will not be moved to object storage. This restriction applies even if the SnapMirror policy is later changed to disable long-term retention.
  • When you create or edit a backup policy when no volumes are assigned to the policy, the number of retained backups can be a maximum of 1018. After you assign volumes to the policy, you can edit the policy to create up to 4000 backups.
  • When backing up data protection (DP) volumes:
    • Relationships with the SnapMirror labels app_consistent and all_source_snapshot will not be backed up to the cloud.
    • If you create local copies of snapshots on the SnapMirror destination volume (irrespective of the SnapMirror labels used), these snapshots will not be moved to the cloud as backups. You must create a snapshot policy with the desired labels on the source DP volume so that NetApp Backup and Recovery can back them up.
  • FlexGroup volume backups cannot be moved to archival storage.
  • FlexGroup volume backups can use DataLock and Ransomware protection if the cluster is running ONTAP 9.13.1 or greater.
  • SVM-DR volume backup is supported with the following restrictions:
    • Backups are supported from the ONTAP secondary only.
    • The snapshot policy applied to the volume must be one of the policies recognized by NetApp Backup and Recovery, including daily, weekly, monthly, etc. The default "sm_created" policy (used for Mirror All Snapshots) is not recognized and the DP volume will not be shown in the list of volumes that can be backed up.
    • SVM-DR and volume backup and recovery work fully independently when the backup is taken from either the source or destination. The only restriction is that SVM-DR does not replicate the SnapMirror cloud relationship. In the DR scenario when the storage VM goes online in the secondary location, you must manually update the SnapMirror cloud relationship.
  • MetroCluster support:
    • When you use ONTAP 9.12.1 GA or greater, backup is supported when connected to the primary system. The entire backup configuration is transferred to the secondary system so that backups to the cloud continue automatically after switchover. You do not need to set up backup on the secondary system (in fact, you are restricted from doing so).
    • When you use ONTAP 9.12.0 and earlier, backup is supported only from the ONTAP secondary system.
    • Beginning with ONTAP 9.18.1, FlexGroup volume backups are supported in MetroCluster configurations.
  • Ad-hoc volume backup using the Backup Now button is not supported on data protection volumes.
  • SM-BC configurations are not supported.
  • ONTAP does not support fan-out of SnapMirror relationships from a single volume to multiple object stores; therefore, this configuration is not supported by NetApp Backup and Recovery.
  • WORM/Compliance mode on an object store is supported on Amazon S3, Google Cloud Platform (GCP), Azure, and StorageGRID at this time. This is known as the DataLock feature, and it must be managed by using NetApp Backup and Recovery settings, not by using the cloud provider interface.
Restore limitations for ONTAP volumes
These limitations apply to both the Search & Restore and the Browse & Restore methods of restoring files and folders; unless called out specifically.
  • Restoring folders from local snapshots is not supported.
  • Restoring files and folders in a disaster recovery (DR) configuration: After a failover, volumes on a storage VM configured for DR retain pre-existing SnapMirror relationships in a broken-off state. Attempts to restore files or folders that create temporary SnapMirror RST relationships are blocked by ONTAP because the destination volume already has a relationship.
  • Browse & Restore can restore up to 100 individual files at a time.
  • Search & Restore can restore one file at a time.
  • When using ONTAP 9.13.0 or greater, Browse & Restore and Search & Restore can restore a folder along with all files and sub-folders within it.
    When using a version of ONTAP greater than 9.11.1 but before 9.13.0, the restore operation can restore only the selected folder and the files in that folder - no sub-folders, or files in sub-folders, are restored.
    When using a version of ONTAP before 9.11.1, folder restore is not supported.
  • Directory/folder restore is supported for data that resides in archival storage only when the cluster is running ONTAP 9.13.1 and greater.
  • Directory/folder restore is supported for data that is protected using DataLock only when the cluster is running ONTAP 9.13.1 and greater.
  • The file being restored must be using the same language as the language on the destination volume. You will receive an error message if the languages are not the same.
  • The High restore priority is not supported when restoring data from Azure archival storage to StorageGRID systems.
  • If you back up a DP volume and then decide to break the SnapMirror relationship to that volume, you cannot restore files to that volume unless you also delete the SnapMirror relationship or reverse the SnapMirror direction.
  • Quick restore limitations:
    • The destination location must be a Cloud Volumes ONTAP system using ONTAP 9.13.0 or greater.
    • It is not supported with backups located in archived storage.
    • FlexGroup volumes are supported only if the source system from which the cloud backup was created was running ONTAP 9.12.1 or greater.
    • SnapLock volumes are supported only if the source system from which the cloud backup was created was running ONTAP 9.11.0 or greater.
Enabling indexing in a disaster recovery configuration
When enabling indexing on a storage VM cluster in a disaster recovery (DR) configuration, an error appears stating the operation is not permitted on a Vserver that is configured as the destination for Vserver DR. Despite the error, the backend process sets the snapdiff-rpc-server status to "on" for the source storage VMs. After the storage VM DR policy schedule runs, this status propagates to the destination storage VMs.
Workaround: Wait for the storage VM DR policy schedule to run after the initial error, then try enabling indexing again.
