Configure NetApp Backup and Recovery settings
Contributors guillermotome
Configure Backup and Recovery settings to add credentials for workloads, integrate with existing infrastructure, and prepare backup and restore operations.
Add credentials for host resources
Add credentials for host resources. NetApp Backup and Recovery uses these credentials to discover workloads and apply backup policies.
If you don't have credentials, create them with permissions to access and manage host workloads.
You need to configure the following types of credentials:
  • Microsoft SQL Server credentials
  • SnapCenter Windows host credentials
  • Windows guest OS credentials used when restoring guest files or folders
  • Oracle Database credentials
  • Linux host credentials
Required NetApp Console role
Backup and Recovery super admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
Steps
  1. From the NetApp Backup and Recovery menu, select Settings.
  2. Select the down arrow for Credentials.
  3. Select Add new credentials.
  4. Enter information for the credentials. Different fields appear depending on the authentication mode you select. Hover over the Information i icon for more information about the fields.
    • Credentials name: Enter a name for the credentials.
    • Authentication mode: Select Windows, Microsoft SQL, Oracle Database, or Linux.
      Tip For Microsoft SQL Server workloads, you must enter credentials for both Windows and Microsoft SQL Server, requiring two sets of credentials.
      Windows
      1. If you selected Windows:
        • Agents: Select a Console agent from the list.
        • Domain and user name: Enter the NetBIOS or domain FQDN and user name for the credentials.
        • Password: Enter the password for the credentials.
      1. If you selected Microsoft SQL Server:
        • Hosts: Select a discovered SQL Server host address.
        • SQL Server instance: Select a discovered SQL Server instance.
      Oracle Database
      1. If you selected Oracle Database:
        • User name: Enter the user name for the credentials.
      Linux
      1. If you selected Linux:
  5. Select Add.
Edit credentials for host resources
You can later edit the password for any credentials that you have created.
Steps
  2. Select the down arrow to expand the Credentials section.
  3. Select the Actions icon Actions option > Edit credentials.
  4. Select Save.
Maintain VMware vCenter settings
Provide VMware vCenter Server credentials to discover workloads for backup. If you don't have credentials, create them with permissions to access and manage VMware vCenter Server workloads.
Steps
  2. Select the down arrow to expand the VMware vCenter section.
  3. Select Add vCenter.
  4. Enter the VMware vCenter Server information.
    • vCenter FQDN or IP address: Enter an FQDN or the IP address for the VMware vCenter Server.
    • Username and Password: Enter the username and password for the VMware vCenter Server.
    • Port: Enter the port number for the VMware vCenter Server.
    • Protocol: Select HTTP or HTTPS.
  5. Select Add.
Import and manage SnapCenter host resources
If you previously used SnapCenter to back up your resources, you can import and manage those resources in NetApp Backup and Recovery. This option enables you to import SnapCenter server information to register multiple SnapCenter servers and discover database workloads.
This is a two-part process:
  • Import SnapCenter Server application and host resources
  • Manage selected SnapCenter host resources
Backup and Recovery super admin or Backup and Recovery backup admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
This first step imports host resources from SnapCenter and displays those resources in the NetApp Backup and Recovery Inventory page. At that point, the resources are not yet managed by NetApp Backup and Recovery.
Tip After you import SnapCenter host resources, NetApp Backup and Recovery does not take over protection management. To do so, you must explicitly select to manage these resources in NetApp Backup and Recovery.
Steps
  2. Select the down arrow to expand the Import from SnapCenter section.
  3. Select Import from SnapCenter to import the SnapCenter resources.
  4. Enter SnapCenter application credentials:
    1. SnapCenter FQDN or IP address: Enter the FQDN or IP address of the SnapCenter application itself.
    2. Port: Enter the port number for the SnapCenter Server.
    3. Username and Password: Enter the username and password for the SnapCenter Server.
    4. Console agent: Select the Console agent for SnapCenter.
  5. Enter SnapCenter server host credentials:
    1. Existing credentials: If you select this option, you can use the existing credentials that you have already added. Enter the credentials name.
    2. Add new credentials: If you don't have existing SnapCenter host credentials, you can add new credentials. Enter the credentials name, authentication mode, user name, and password.
  6. Select Import to validate your entries and register the SnapCenter Server.
    Note If the SnapCenter Server is already registered, you can update the existing registration details.
Result
The Inventory page shows the imported SnapCenter resources.
Manage SnapCenter host resources
After you import the SnapCenter resources, manage those host resources in NetApp Backup and Recovery. After you select to manage those imported resources, NetApp Backup and Recovery can back up and recover the resources that you are importing from SnapCenter. You no longer need to manage those resources in SnapCenter Server.
Steps
  1. After you import the SnapCenter resources, on the Inventory page that appears, select the SnapCenter resources that you imported that you want to have NetApp Backup and Recovery manage from now on.
  2. Select the Actions icon Actions option > Manage to manage the resources.
  3. Select Manage in NetApp Console.
    The Inventory page shows Managed under the host name to indicate that the selected host resources are now managed by NetApp Backup and Recovery.
Edit imported SnapCenter resources
You can later re-import SnapCenter resources or edit the imported SnapCenter resources to update the registration details.
You can change only the port and password details for the SnapCenter Server.
Steps
  2. Select the down arrow for Import from SnapCenter.
    The Import from SnapCenter page shows all previous imports.
  3. Select the Actions icon Actions option > Edit to update the resources.
  4. Update the SnapCenter password and port details, as needed.
  5. Select Import.
Add a KVM management platform
If you use the Apache CloudStack management platform to manage KVM resources, integrate it with NetApp Backup and Recovery so that Backup and Recovery can discover and protect the managed KVM hosts and VMs.
Steps
  2. Select the down arrow to expand the Management platform section.
  3. Select Add management platform credential.
  4. Enter the following information:
    • Management platform IP address or FQDN: Enter the IP address or an FQDN of the management platform.
    • API key: Enter the API key to use to authenticate API requests.
    • Secret Key: Enter the secret key to use to authenticate API requests.
    • Port: Enter the port to use for communication between Backup and Recovery and the management platform.
    • Agents: Select a Console agent to use to facilitate communication between Backup and Recovery and the management platform.
  5. When finished, select Add.
Configure log directories in snapshots for Windows hosts
Before you create policies for Windows hosts, configure log directories in snapshots to store the logs generated during the backup process.
Backup and Recovery super admin, Backup and Recovery backup admin or Backup and Recovery restore admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
Steps
  1. From the NetApp Backup and Recovery menu, select Inventory.
  2. From the Inventory page, select a workload and then select the Actions icon Actions option > View details to display the workload details.
  3. From the Inventory details page showing Microsoft SQL Server, select the Hosts tab.
  4. From the Inventory details page, select a host and select the Actions icon Actions option > Configure log directory.
  5. Either browse or enter the path for the log directory.
  6. Select Save.
Create an execution hook template
You can create a custom execution hook template that you can use to perform actions before or after a data protection operation on an application.
Note Templates that you create here are only usable when protecting Kubernetes workloads.
Steps
  1. In the Console, go to Protection > Backup and recovery.
  2. Select the Settings tab.
  3. Expand the Execution hook template section.
  4. Select Create execution hook template.
  5. Enter a name for the execution hook.
  6. Optionally, choose a type of hook. For example, a post-restore hook is run after the restore operation is complete.
  7. In the Script text box, enter the executable shell script that you want to run as part of the execution hook template. Optionally, you can select Upload script to upload a script file instead.
  8. Select Create.
    After you create the template, it appears in the list of templates in the Execution hook template section.
Create a resource transformation template
Create resource transformation templates to store common transformations you apply to resources during restore operations.
Steps
  2. Select the down arrow to expand the Resource transformation template section.
  3. Select Create template.
  4. Enter a name for the resource transformation template.
  5. Optionally, enter a template description.
  6. Describe the target resource:
    1. Enter the resource kind (such as Pod or Deployment). This field is required.
    2. Optionally, enter a resource group, version, and name.
  7. Build an operation:
    1. Choose an operation from the Operation list.
    2. Enter the JSON path that the operation applies to.
    3. If applicable, enter a value to add or update, or a JSON path to move from.
      These fields only appear for operations that require them.
    4. To add another operation to this template, select Add operation.
  8. When finished, select Add.
