Discover offsite backup targets in NetApp Backup and Recovery
Contributors guillermotome
Discover or manually add offsite backup targets such as AWS S3, Azure Blob Storage, Google Cloud Storage, or StorageGRID so you can store backups outside your primary environment.
Discover a backup target
Configure your backup targets (Amazon Web Services (AWS) S3, Microsoft Azure Blob Storage, Google Cloud Storage, or StorageGRID) before you use NetApp Backup and Recovery.
You can discover these targets automatically or manually add them.
Provide credentials to access the storage account. NetApp Backup and Recovery uses these credentials to discover and verify access to your backup target buckets.
Before you begin
You need to discover at least one workload before you can add an offsite backup target.
Steps
  1. From the NetApp Backup and Recovery menu, select Backup targets.
  2. Select Discover backup target.
  3. Select one of the available backup target types: AWS, Azure, StorageGRID, ONTAP S3, or GCP.
  4. Select Next.
  5. (For AWS and Azure backup targets only) In the Choose credentials location section, choose the location where the credentials reside and then choose how to associate the credentials.
  6. Select Next.
  7. Enter the credentials information. The information differs depending on the type of backup target you selected and the credentials location that you chose.
    • For AWS:
      • Credential name: Enter the AWS credential name.
      • Access key: Enter the AWS access key.
      • Secret key: Enter the AWS secret key.
    • For Azure:
      • Credential name: Enter the Azure Blob Storage credential name.
      • Client secret: Enter the Azure Blob Storage client secret.
      • Application (client) ID: Enter the Azure Blob Storage application ID.
      • Directory tenant ID: Enter the Azure Blob Storage tenant ID.
    • For StorageGRID:
      • Credential name: Enter the StorageGRID credential name.
      • Gateway Node FQDN: Enter an FQDN for the StorageGRID gateway node.
      • Port: Enter the port number for StorageGRID.
      • Access key: Enter the StorageGRID S3 access key.
      • Secret key: Enter the StorageGRID S3 secret key.
    • For ONTAP S3:
      • Credential name: Enter the ONTAP S3 credential name.
      • Gateway Node FQDN: Enter an FQDN for the ONTAP S3 gateway node.
      • Port: Enter the port number for ONTAP S3.
      • Access key: Enter the ONTAP S3 access key.
      • Secret key: Enter the ONTAP S3 secret key.
    • For GCP:
      • Credentials name: Enter the Google Cloud credential name.
      • Access key: Enter the Google Cloud access key.
      • Secret key: Enter the Google Cloud secret key.
  8. Select Discover.
Add a bucket for a backup target
Manually add a bucket to an offsite backup target instead of having NetApp Backup and Recovery discover buckets automatically.
Steps
  2. Select a target and on the right, select the Actions Actions icon icon and select Add bucket.
  3. Enter the bucket information. The information differs depending on the type of backup target you selected.
    • For AWS:
      • Bucket name: Enter the name of the S3 bucket. The prefix of "netapp-backup" is a required prefix and is automatically added to the name you provide.
      • AWS account: Enter the AWS account name.
      • Bucket region: Enter the AWS region for the bucket.
      • Enable S3 Object Lock: Select this option to enable S3 Object Lock for the bucket. S3 Object Lock prevents objects from being deleted or overwritten for a specified retention period, providing an additional layer of data protection. You can enable this only when you are creating a bucket and you cannot turn it off later.
        • Governance mode: Select this option to enable governance mode for the S3 Object Lock bucket. Governance mode enables you to protect objects from being deleted or overwritten by most users, but allows certain users to alter the retention settings.
        • Compliance mode: Select this option to enable compliance mode for the S3 Object Lock bucket. Compliance mode prevents any user, including the root user, from altering the retention settings or deleting objects until the retention period expires.
      • Versioning: Select this option to enable versioning for the S3 bucket. Versioning enables you to keep multiple versions of objects in the bucket, which can be useful for backup and recovery purposes.
      • Tags: Select tags for the S3 bucket. Tags are key-value pairs that can be used to organize and manage your S3 resources.
      • Encryption: Select the type of encryption for the S3 bucket. The options are either AWS S3-managed keys or AWS Key Management Service key. If you select AWS Key Management Service keys, you must provide the key ID.
    • For Azure:
      • Subscription: Select the name of the Azure subscription.
      • Resource group: Select the name of the Azure resource group.
      • Instance details:
        • Storage account name: Enter the name of the Azure Blob Storage account.
        • Azure region: Enter the Azure region for the storage account.
        • Performance type: Select the performance type of either standard or premium for the Azure Blob Storage account, indicating the level of performance required.
        • Encryption: Select the type of encryption for the Azure Blob Storage account. The options are either Microsoft-managed keys or customer-managed keys. If you select customer-managed keys, you must provide the key vault name and key name.
    • For StorageGRID:
      • Backup target: Select the name of the StorageGRID backup target.
      • Bucket name: Enter the name of the StorageGRID bucket.
      • Region: Enter the StorageGRID region for the bucket.
      • Enable versioning: Select this option to enable versioning for the StorageGRID bucket. Versioning enables you to keep multiple versions of objects in the bucket, which can be useful for backup and recovery purposes.
      • Object locking: Select this option to enable object locking for the StorageGRID bucket. Object locking prevents objects from being deleted or overwritten for a specified retention period, providing an additional layer of data protection. You can enable this only when you are creating a bucket and you cannot turn it off later.
      • Capacity: Enter the capacity for the StorageGRID bucket. This is the maximum amount of data that can be stored in the bucket.
    • For ONTAP S3:
      • Backup target: Select the name of the ONTAP S3 backup target.
      • Bucket name: Enter the name of the ONTAP S3 bucket.
      • Capacity: Enter the capacity for the ONTAP S3 bucket. This is the maximum amount of data that can be stored in the bucket.
      • Enable versioning: Select this option to enable versioning for the ONTAP S3 bucket. Versioning enables you to keep multiple versions of objects in the bucket, which can be useful for backup and recovery purposes.
      • Object locking: Select this option to enable object locking for the ONTAP S3 bucket. Object locking prevents objects from being deleted or overwritten for a specified retention period, providing an additional layer of data protection. You can enable this only when you are creating a bucket and you cannot turn it off later.
    • For GCP:
      • Bucket name: Enter the name of the Google Cloud bucket.
      • GCP project: Select the name of the Google Cloud project.
      • Bucket region: Select a region for the Google Cloud bucket.
      • Object locking: Select this option to enable retention periods for objects in this bucket. While a retention period is in effect, objects cannot be modified or deleted and are immutable until the period expires. If you enable this option for a bucket, it cannot be turned off.
  4. Select Add.
Change credentials for a backup target
Enter the credentials needed to access the backup target.
Steps
  2. Select a target and on the right, select the Actions Actions icon icon and select Change credentials.
  3. Enter the new credentials for the backup target. The information differs depending on the type of backup target you selected.
  4. Select Done.
