Back up a Kubernetes application using the NetApp Backup and Recovery web UI
Contributors guillermotome
Use the web UI to perform an on-demand backup of a Kubernetes application.
Required NetApp Console role
Backup and Recovery super admin or Backup and Recovery backup admin. Learn about NetApp Backup and Recovery access roles. Learn about NetApp Console access roles for all services.
Manually create a backup of a Kubernetes application to establish a baseline for future backups and snapshots, or to ensure the most recent data is protected.
Steps
  1. In NetApp Backup and Recovery, select Inventory.
  2. Choose a Kubernetes instance and select View to access the resources associated with that instance.
  3. Select the Applications tab.
  4. In the applications list, select an application you want to back up and choose the associated Actions menu.
  5. Select Backup now.
  6. Confirm the correct application is selected.
  7. Select Back up.
Result
The Console creates a backup of the application and displays the progress in the Monitoring area of Backup and Recovery. The backup is created based on the protection policy associated with the application.
