Mount, unmount, and catalog Oracle Database recovery points with NetApp Backup and Recovery
Contributors guillermotome
Mount an Oracle Database recovery point when you need access to the database in a controlled state for recovery operations. If automatic cataloging is disabled, you can manually catalog the recovery point metadata in the RMAN recovery catalog.
If you configure the protection policy for a database to retain archive logs, you can mount recovery points to view the database change history.
Steps
  1. From the NetApp Console menu, select Protection > Backup and Recovery.
  2. Select the Oracle tile.
  3. In the Backup and Recovery menu, select Inventory.
  4. For the Oracle Database workload in the list, select View.
  5. Select the Databases menu.
  6. Choose a database from the list and select the Actions icon Actions option > View protection details.
    A list of recovery points for that database appears.
  7. Choose a recovery point from the list and select the Actions icon Actions option > Mount.
  8. In the dialog that appears, do the following:
    1. Choose the host that should mount the recovery point from the list.
    2. Select which location Backup and Recovery should use to mount the recovery point. For the preview release, mounting from the object store is not supported.
      The mount path that Backup and Recovery should use is displayed.
  9. Select Mount.
    The recovery point is mounted on the Oracle host.
Unmount an Oracle Database recovery point
Unmount the recovery point when you no longer need to view changes made to that database.
Steps
  4. For the Oracle workload in the list, select View.
  7. Choose a recovery point from the list and select the Actions icon Actions option > Unmount.
  8. Confirm the action by selecting Unmount.
Catalog an Oracle Database recovery point
Manually catalog a recovery point when you need to preserve its backup and recovery operation metadata. The metadata is stored according to the Configure RMAN catalog settings you choose for the database (in the target control file by default). You only need to manually catalog if automatic cataloging is disabled in the associated protection policy.
Steps
  7. Choose a recovery point from the list and select the Actions icon Actions option > Catalog.
  8. Confirm the action by selecting Catalog.
